syalk1120
why OUTPUT SIGNALS MISSING IN MODELSIME
hi,i cann't find my design output signals in modelsim simulation while it goes well invoted modelsim for simulation in ISE9.2.Why?  Can anybody reply to me?
THX!
syalk1120
Hi,thanks for chenhongyi123 's reply. It's the key for the solution.it can be solved only use the tcl command 'vsim -novopt  work.file' , while  the menu cann't.
Thanks a lot.
chenhongyi123
It maybe vopt by ModelSim.
 uncheck "compile -> compile options-> Use vopt flow "  in modelsim, and  try again
syalk1120
chenhongyi123 ,thanks for your reply!
and I still cann't solved the problem. I found it strange that when my design was not including sequential logic,such as 'always'sentence, the output can be seen at the waveform.
hope somebody can give me a hand.
syalk1120
Thanks a lot.
