Visitor aae65
wrong results using ISIM
I am simulating a vhdl module and i am getting illogical results in the ISIM. I attached three photos in which i am using the step function to track the parts of the code that are being used. When i set the flag to 1, the statement under the case when the flag is 0 is visited after it (and vice versa). These statement are all inside a process and should be executed sequentially, and i am not sure of the cause behind this bahavior. Any thoughts?
Thank You
Teacher eilert
Re: wrong results using ISIM
seems like you are not aware of the difference between signals and variables in VHDL.
Signal drivers are updated at the end of a process or the next wait statement.
Until then,reading from a signal always gives the value it had when entering the process.
Only variables are updated immediately inside aprocess.
  a <= b;
  a <= a+a;
results in 2*a inside a process.
  a := b;
  a := a+a;
results in 2*b, notice the difference.
Have a nice simulation
  Eilert
Teacher eilert
  a <= b;
  a <= a+a;
  a := b;
  a := a+a;
  Eilert
Visitor aae65
Thank you very much!
