.xcix compile issue in irun
   I'm trying to compile a xilinx fifo file which is of .xcix format with the help of Cadence IRUN.
please share some suggestion on how to compile with cadence tools/
regards,
mahesh
Re: .xcix compile issue in irun
@omahesh
If your query is resolved, please mark the Answer as "Accept as solution" and close this thread.
Asit
@omahesh
Do "export_ip_user_files" to extract the IP files required for simulation. Then "export_simulation" and use the scripts generated.
Sravanthi
@omahesh
Did that help?
Sravanthi
   Thank you for your suggestion and this is helped me to extract .v from xcix file.
mahesh
@omahesh
Asit
