xelab : use 64-bit version while running under Win 8.1 64-bit
Vivado 2014.1 Web Edition
While running under Win 8.1 (64-bit) with 8GB of physical memory, I receive the following error while trying to simulate a design:
ERROR: [XSIM 43-4177] This design requires more memory than a 32-bit operating system can support. Please use 64-bit version of the software.
The shortcut used to invoke Vivado:
C:\Xilinx\Vivado\2014.1\bin\unwrapped\win64.o\vvgl.exe C:\Xilinx\Vivado\2014.1\bin\vivado.bat
This looks like it is trying to run the 64-bit version. How do I ensure I am running the 64-bit version?
In Vivado IDE, go to Help --> About Vivado. If you are using 64 bit version it will be mentioned like below
Deepika.
Deepika.
Deepika.
Deepika.
If in case you are using a 64-bit Vivado and still seeing the error, then please post your so that it can be examined.
Debraj
Problem solved. It's a simulator bug. Yes, it is a bug. Even if you argue that I used illegal syntax, the simulator should not: * Run out of memory just because of bad syntax. * Tell me that I need to run the 64-bit version when, in fact, I am running the 64-bit version. The problem is caused by using concatenated vectors (in VHDL) connected to input ports when a component is instantiated. (I did receive a warning about this; but just a warning.) For example... inst : mycomponent port map ( ... invector16 => vectorb8 & vectora8, invector32 => vectord8 & vectorc8 & vectorb8 & vectora8, ... ); By creating new vectors, the problem was solved and the simulator ran uneventfully... catvect16 <= vectorb8 & vectora8; catvect32 <= vectord8 & vectorc8 & vectorb8 & vectora8; inst : mycomponent port map ( ... invector16 => catvect16, invector32 => catvect32, ... );
I use 64-bit vivado & 64-bit ubuntu 14.04.  But I get this error
Jothi
Hello Jothi,
How did you confirm that you are using 64-bit?
Also how much RAM you have on the machine?
Vinay
