xsim crashes
I am running a timing simulation on a design and the simulator (XSIM) crashes after running XELAB, pointing to line 66 of FDCE model in unisims.  RTL simulation passes, without any issues.
Below is the extract of the error messages:
FATAL_ERROR: Vivado Simulator kernel has discovered an exceptional condition from which it cannot recover. Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support.
Time: 0 ps Iteration: 1 Process: /top_TB/inst_1/inst_2/inst_3_core/inst_4/Forked39_545408
File: /usr/pack/xilinx-vivado-2017.2-kl/Vivado/2017.2/data/verilog/src/unisims/FDCE.v
HDL Line: /usr/pack/xilinx-vivado-2017.2-kl/Vivado/2017.2/data/verilog/src/unisims/FDCE.v:66
Tool: Vivado 2017.2
Platform :  Both Windows 10 and Linux
Device : Zync UltraScale +
Is there a way to resolve or work around this.
Ravi
Re: xsim crashes
Hi @xilinxmax
>>I have to check if there is a way to generate the SAIF files using Cadence Simulators
Refer to commands mentioned in page 43 of the below link:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug900-vivado-logic-simulation.pdf
Hope this helps.
Rohit
Rohit
Re: xsim crashes
Hi @xilinxmax,
Can you please try running your design in latest version of Vivado 2017.4 and check. If you still observe the issue, then can you please share the testcase to reproduce this issue at our end and check.
Thanks & Regards,
Sravanthi B
Thanks & Regards,
Sravanthi B
Re: xsim crashes
I am not sure I can replicate the issue with a smaller testcase, and I can't provide the entire database due to company policies.
The intent of the timing simulation I am doing is to generate power report.
Now that Vivado XSIM is crashing, I am using Cadence IES for simulation, for now.  But, by using IES, I can't generate SAIF file from simulation (open_saif, log_saif, etc, which are Vivado commands).
Ravi
Re: xsim crashes
Hi @xilinxmax
Hope this helps.
Rohit
Rohit
