Newbie vitjka
xsim fails to include signals used in procedures into sensitivity list of the process(all)
Hi, this issue is still present in vivado 2019.1, here is the testcase:
library ieee;
use ieee.std_logic_1164.all;
entity process_all_tb is end entity process_all_tb;
architecture simul of process_all_tb is
signal clock: std_ulogic := '0';
signal ff_not_working: std_ulogic := '0';
signal ff_working: std_ulogic := '0';
begin
clock <= transport not clock after 5 ns;
-- xsim fails to include signals used in procedures into sensitivity list of the process(all):
process(all)
procedure flip_flop is
begin
if clock = '1' then
ff_not_working <= '0';
else
ff_not_working <= '1';
end if;
end procedure;
begin
flip_flop;
end process;
-- it works correctly here
process(all)
begin
if clock = '1' then
ff_working <= '0';
else
ff_working <= '1';
end if;
end process;
end architecture simul;
Re: xsim fails to include signals used in procedures into sensitivity list of the process(all)
Hi @vitjka ,
Thank you for the test code, I have run it in the latest version of the tools and can see that the signal in the procedure doesn't change as you would expect.
I also checked it against Questa and can see the signal changing.
I will create a Change Request to get this issue looked at and hopefully fixed in a future release of the tools.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
