xsim interrupted
  I tried to runxapp1180's simulation on Vivado 2018.2 and xsim sent an error message to me as shown below:
-------------------------------error message start----------------------------------------
PHY_INIT: Write Calibration completed at 54552600.0 ps
55693000.0 ps : Initializing DDR3 memory to 0
Command failed: Simulator command interrupted.
Simulation engine not responding
The simulator has terminated in an unexpected manner. Please review the simulation log (xsim.log) for details.
run: Time (s): cpu = 00:13:08 ; elapsed = 00:18:40 . Memory (MB): peak = 6208.891 ; gain = 3.000 ; free physical = 7234 ; free virtual = 7301
-------------------------------error message end----------------------------------------
Please see attachment also.
I had tried to run this simulation on windows, centos 7 and ubuntu 16.04. Only centos 7 has no problem. Could you give me some suggestions?
B/R
Jerry Yau
Re: xsim interrupted
Hi @jerry.yau ,
I have tried simulating the xapp1180 in Vivado 2018.3 and on windows7 machine, i didnot come across any interruptions during behavioral simulation as shown below:
Hence, can you please try using Vivado 2018.3 or latest 2019.1 and check if you are still facing this issue.
Thanks & Regards,
Sravanthi B
Hi, @bandi .
Thanks for your reply. I had no problem if vivado is 2018.3 on ubuntu. However, this is not a new project. I don't want to use new vivado.
B/R
Jerry Yau
