xsimk makes my workstation run out of memory
Vivado- 2018.2
OS- Win7 Pro, SP1, 64bit
Processor- i7-4770 CPU @ 3.40GHz
RAM- 16.0GB
I kept a simulation running overnight and this is what I observed in the morning.
Related thread: https://forums.xilinx.com/t5/Simulation-and-Verification/Any-running-hours-limitation-for-xsim-in-Vivado-2018-2/td-p/903140
Is it a bug? What is the solution for long term running xsimk?
Re: xsimk makes my workstation run out of memory
After migrating to Viv2018.3, I don't see xsimk memory usage growing with increasing time.
Seems like it has been fixed.
Scholar drjohnsmith
Is it a bug
yes
is it xilinx , I'd say no.
I have simulations of big designs that run on Xeon machines, and take 3 to 5 days to run,
      BUT , they dont run windows 7, but Linux,
           they do not run other programs like anti virus,
                and they have 64 G of memory
remember . a long time before you run out of memory , the machine is thrashing the hard drive , and very slow.
I'm afraid the most likely problem you have is your IT department,  and the fact your running multiple dis connected programs on the one machine,
@drjohnsmith,
Would anyone from Xilinx care to take up this issue?
Scholar richardhead
Are you sure its not a problem in the testbench itself?
Are you using Access types in the VHDL? are you deallocating them when you've finished with them, or just calling new on an old objects? Do you have any functions that do:
return var.all;
When using access types, it can be easy to create memory leaks as VHDL has no garbage collection. So returns like the above will leave the pointer in the function still alive even though you have no way to access it any more.
Hi @gin_xil,
Can you please share the archived project to check at our end. Please let me know if you want me to send you an FTP link to share the project.
Thanks & Regards,
Sravanthi B
@richardhead,
Nothing like that.
@bandi,
Not possible to share the project.
Any more info?
Scholar richardhead
@gin_xil
Without sharing the project, or at least an example that also exhibits the behaviour, it is we can only guess as to what is happening.
The only guess is you are logging a lot of signals during the simulation.
@richardhead,
Don't you work on projects with NDA agreements?
You can ask for other info which is possible/realistic to provide! I will answer them happily.
Scholar richardhead
@gin_xil
Yes I do. But I also understand that without direct information or an example that shows the project, it can be difficult to diagnose the issue.  As others have pointed out, they have no issue with large or long simulations.
So on to some probing about the test:
How is the data generated in the testbench?
How is the data driven in the testbench?
I notice you're dealing with IPv6 packets - how do you control the variable length on data generation?
Are you logging all signals from every entity, or just the DUT? Is this really necessary?
Scholar drjohnsmith
is this thread related to the other thread running in the forums about running out of disc space ?
@drjohnsmith,
Yes, please see my 1st post! have already mentioned that.
@richardhead,
How is the data generated in the testbench? How is the data driven in the testbench?
I have a clock and fixed sized arrays which are driving rmii o/p ports. There is an iteration count which determines the num of frames generated.
Note that the DUT has 36 ports so in the TB, 36 iterations of the rmii frame generator is running. Each generator is pushing about 100 frames.
It is easy to generate in a for loop. Using a generic parameter making sure that the 46 >= frame_length <= 1500
I am logging a lot of signals (which are not all the signals of the DUT), because I should be able to see where a failure occurs.
As mentioned before this is a huge design which has 36 Ethernet data logging ports, these frames are concentrated together, buffered in a 2 GB on-board RAM (MIG core used) and finally push out of the DUT using a Gigabit RGMII i/f. There are many stuffs happening to these frames inside this complete data path, but it is not necessary to divulge the details about them.
I am almost certain my DUT or TB has nothing to do with this failure.
Scholar richardhead
But ultimately, it is about your testbench design.
I have testbenches for DUTs that use a 10GB Ethernet interface. I can run 10000+ IPv4 packets through the DUT and out via a AXI IC BFM (that in reality connects to a 2GB DDR) in a matter of minutes, with the sim never using more than 50Mb of ram, and I log every signal.
I still summise you're simulating and logging too much.
More questions:
I have a clock and fixed sized arrays which are driving rmii o/p ports. There is an iteration count which determines the num of frames generated. Note that the DUT has 36 ports so in the TB, 36 iterations of the rmii frame generator is running. Each generator is pushing about 100 frames.
Are the packets generated in the testbench? or read from a file? Do you generate a whole packet in a single delta cycle and stream it in clock by clock? or do you generate a single bus transaction per clock? I ask because if you create the whole packet as a signal in a large array, that is going to require a HUGE amount of ram compared to if it was a variable.(and then multiply this up if you have several channels running in parrallel).
Is this really necessary all the time? Especially if you have signals that are large arrays.
Do you really need to simulate a (slow) Gigagabit controller and (especailly slow) mig. Are you verifying the MIG/Eth controller or the DUT? ideally, you would switch these things out for BFMs. Using the timing accurate models is hiddeously slow and resource hogs. If you create models of these things, you can change an hours long sim to a minutes long one. You can then do a final sim with the real models or simply skip this (as I do) and put it on hardware.
@richardhead,
Can likely be the cause, because I am logging many many signals.
But my colleague also simulated the same design with similar Workstation resources, logging a much smaller num of signals. He too faced the same error message of xsimk.
I stream it clock by clock.
That's a bad coding style, I am not doing it.
You are misunderstanding or making an assumption. Those large arrays have nothing to do with my DUT.  Most of the logged signals are from my DUT. Only a bare minimum of my TB signals are logged.
Actually the MIG interface signals are not logged (it is working fine). I mentioned it so that you have an idea about the design. All I am interested are the RMII signals and TEMAC signals at the logging interface (36 logging ports) and the RGMII Gigabit outgoing interface.
Thanks Richard for your efforts to help.
What I am really surprised is the neutral attitude of Xilinx staff regarding this problem. Only one ask about sharing the project and then no response. Not even an attempt from them to understand the problem.
And then from time to time they want us to give them feedback and rate them!
Scholar drjohnsmith
Its no excuse, but the majority of the xilinx people seem to work on Verilog and Linux,
Scholar dpaul24
Another development....
We have made a standalone machine having i7 processor, 12 GB RAM and Win7 OS.
It has no MS Office, Antivirus or other stuff running that might occupy RAM.
There also we get the error message that xsimk runs out of memory.
FPGA enthusiast!
All PMs will be ignored
Visitor xion_pecher
Hello Sravanthi B,
we have the same problems with the Simulation in both versions (.1 and .2) of Vivado 2018.
I attached a small "Counter" project with TestBench and ready to run.
