About IP core
In the IP core generator, I didn't find peripherals like, SPI, I2C, UART.
Does Xilinx offer these Cores? Are they free or not? Are they open source? Where can I find them.
If I can not afford them, where can I find free version? Open source should be better.
-Rohs
Re: About IP core
  For SPI, IIC and UART, we provide IP Core in SDK.
  If you want to use it in Pure Logic, I think this is easy and you also can find in our Demo Board reference design files.
  http://www.xilinx.com/products/boards/s3astarter/reference_designs.htm
  http://www.xilinx.com/products/boards/s3estarter/reference_designs.htm
XiBin
Anonymous
Not applicable
Re: About IP core
How can i generate ip core for UART in CORE Generator, if i don't want to use EDK, XPS or SDK etc etc???
Instructor
Instructor
Re: About IP core
I believe you do not need to use EDK/SDK/XPS to use one of the Xilinx LogiCore UART cores, but you do need to have a paid license for EDK.
Alternatives:
  • copy or purchase an existing core, if you do not care to learn how to write your own code
  • write your own UART code, which is quite simple
  • use a PicoBlaze to implement a UART (using PicoBlaze code which you can either copy or write for yourself).  There is example code available in the (free) PicoBlaze download files.  See the PicoBlaze Lounge on the Xilinx website for more information.
In any case, you should have an understanding of how asynchronous serial communications work, in general.
There is good information found online in Wikipedia and at fpga4fun.com.
-- Bob Elkind
SIGNATURE:
Summary:
