Can I use VREF pin for TMDS ?
Dear All,
I'm trying to implement TMDS with spartan6lx16
But I confused that can I use VREF pin as TMDS in UCF ?
Additionally,
When I use "VCCAUX = 3.3;" in UCF, Then I found the error message as the below
ERROR:Place:864 - Incompatible IOB's are locked to the same bank 2
Conflicting IO Standards are:
IO Standard 1: Name = LVCMOS33, VREF = NR, VCCO = 3.30, TERM = NONE, DIR =
OUTPUT, DRIVE_STR = 12
List of locked IOB's:
DEBUG<0>
DEBUG<1>
ERROR:Pack:1654 - The timing-driven placement phase encountered an error.
Would you help me what am I supposed to do to resolve this problem?
Community Manager
Community Manager
Re: Can I use VREF pin for TMDS ?
@love119 Your SYS_CLK and SW<0> nets are locked to the same pin A10. Check on this and modify.
Also make sure the UCF matches to the board you are using since seems like you are reusing the same UCF from XAPP495 with modifications where needed.
- Giri
There's no such thing as a stupid question. Feel free to ask but do a quick search to make sure it ain't already answered.
Keep conversing, give Kudos and Accept Solution when you get one.
Community Manager
Community Manager
@love119
Yes you can if there is no VREF based IO Standard being used in that bank. From UG385
Check this AR: https://www.xilinx.com/support/answers/39234.html
What IO Standards do you have in bank 2?
- Giri
@gnarahar
I used
LVCMOS33
in bank2.
Currently, Now I'm debugging with xapp495 example.
"xapp495 vtc demo" does not working.
Debug signals are connected in T9 and R9 in bank2
# Setting VCCAUX for different SPARTAN6LX16 2FT256 board
#VCCAUX = 3.3;
# Reset button and LEDs
NET "RSTBTN"        LOC = "T8";
#NET "LED<0>"        LOC = "H12";
#NET "LED<1>"        LOC = "G13";
#NET "LED<2>"        LOC = "E16";
#NET "LED<3>"        LOC = "E18";
# SYSCLK Input
NET "SYS_CLK"       LOC = A10 	| IOSTANDARD = LVTTL;
# Mechanical Switches (SW)
#NET "SW<0>"         LOC = "A10" | IOSTANDARD = LVCMOS33 ;
#NET "SW<1>"         LOC = "D14" | IOSTANDARD = LVCMOS33 ;
#NET "SW<2>"         LOC = "C14" | IOSTANDARD = LVCMOS33 ;
#NET "SW<3>"         LOC = "P15" | IOSTANDARD = LVCMOS33 ;
# Debug Port # JA1
NET "DEBUG[1]" LOC = T9 | IOSTANDARD = LVCMOS33;
NET "DEBUG[0]" LOC = R9 | IOSTANDARD = LVCMOS33;
# DCM/PLL/BUFPLL positions
#INST "PCLK_GEN_INST" LOC = "DCM_X0Y3";
#INST "PLL_OSERDES"   LOC = "PLL_ADV_X0Y1";
#INST "ioclk_buf"     LOC = "BUFPLL_X1Y0";
# Timing Constraints
NET "clk50m_bufg" TNM_NET = "TNM_CLK50M";
TIMESPEC "TS_CLK50M" = PERIOD "TNM_CLK50M" 50 MHz HIGH 50 % PRIORITY 0 ;
NET "pclk" TNM_NET = "TNM_PCLK";
TIMESPEC "TS_PCLK" = PERIOD "TNM_PCLK" 108 MHz HIGH 50 % PRIORITY 0 ;
NET "pclkx2" TNM_NET = "TNM_PCLKX2";
TIMESPEC "TS_PCLKX2" = PERIOD "TNM_PCLKX2" TS_PCLK * 2;
NET "pclkx10" TNM_NET = "TNM_PCLKX10";
TIMESPEC "TS_PCLKX10" = PERIOD "TNM_PCLKX10" TS_PCLK * 10;
# Multi-cycle paths
#TIMEGRP "bramgrp" = RAMS(enc0/pixel2x/dataint<*>);
#TIMEGRP "fddbgrp" = FFS(enc0/pixel2x/db<*>);
#TIMEGRP "bramra" = FFS(enc0/pixel2x/ra<*>);
#TIMESPEC "TS_ramdo" = FROM "bramgrp" TO "fddbgrp" TS_PCLK;
#TIMESPEC "TS_ramra" = FROM "bramra" TO "fddbgrp" TS_PCLK;
# TMDS pairs on the top
#NET "TMDS(0)"  	LOC = "C7" | IOSTANDARD = TMDS_33 ; # Blue
#NET "TMDSB(0)"  LOC = "A7" | IOSTANDARD = TMDS_33 ;
#NET "TMDS(1)"  	LOC = "D8" | IOSTANDARD = TMDS_33 ; # Red
#NET "TMDSB(1)"  LOC = "C8" | IOSTANDARD = TMDS_33 ;
#NET "TMDS(2)"  	LOC = "B6" | IOSTANDARD = TMDS_33 ; # Green
#NET "TMDSB(2)"  LOC = "A6" | IOSTANDARD = TMDS_33 ;
#NET "TMDS(3)"  	LOC = "B8" | IOSTANDARD = TMDS_33 ; # Clock
#NET "TMDSB(3)"  LOC = "A8" | IOSTANDARD = TMDS_33 ;
NET "TMDS[0]"  	LOC = "F9"    | IOSTANDARD = TMDS_33 | DRIVE = 8  | SLEW = FAST;# Blue
NET "TMDSB[0]"  	LOC = "D9"    | IOSTANDARD = TMDS_33 | DRIVE = 8  | SLEW = FAST;
NET "TMDS[1]"  	LOC = "F10"   | IOSTANDARD = TMDS_33 | DRIVE = 8  | SLEW = FAST;# Red
NET "TMDSB[1]"  	LOC = "E11"   | IOSTANDARD = TMDS_33 | DRIVE = 8  | SLEW = FAST;
NET "TMDS[2]"  	LOC = "E10"   | IOSTANDARD = TMDS_33 | DRIVE = 8  | SLEW = FAST; # Green
NET "TMDSB[2]"  	LOC = "C10"   | IOSTANDARD = TMDS_33 | DRIVE = 8  | SLEW = FAST;
NET "TMDS[3]" 		LOC = "D8"    | IOSTANDARD = TMDS_33 | DRIVE = 8  | SLEW = FAST;# Clock
NET "TMDSB[3]" 	LOC = "C8"    | IOSTANDARD = TMDS_33 | DRIVE = 8  | SLEW = FAST;
Then what am I supposed to do to resolve this problem?
Should I remove
VCCAUX = 3.3;
Community Manager
Community Manager
- Giri
@gnarahar
SW<0> has already commented, is this wrong?
@gnarahar
Would you let me know timing constraints, when the input clock is set as 50Mhz.
Currently I used the below UCF But I'm confused 108Mhz how to work in 50Mhz input clock.
Can I use these constraints for implement at 50mhz input clock ?
