Convert LVDS to CSI-2
Hi all,
I need convert LVDS to CSI-2 support Full HD 1920x1080p @ 60fps. I do not sure XC6SLX25 can do it. Which FPGA I can use in this case?.
Brs,
Bang Duong
Mentor
Mentor
You should read this application note:
XAPP894, by Mark Defossez
Mentor
Mentor
You'll need an Artix device, probably a minimum speed grade of -2.
Can you tell me more about solution? ( any datasheet, guideline, or reference ...). I do not have experience with FPGA.
Mentor
Mentor
