Observer patrick.lewis
Defualt IO states
I am interested in the default state of Spartan 6 and Virtex 4 IO pins.
For start-up we can use HSWAPEN to enable pullups, but what about once a board is programmed and running. If a pin is not defined in the design, does the FPGA continue to use weak pull ups, or do the pins become tri-stated. Has this always been the case?
Teacher eteam00
Setting default IO states for unused pins
The default for unused pins is electrically equivalent to an input with a weak pulldown resistor.  Of course, there is no "input" function associated with unused pins.
See UG628, the BitGen chapter.
In the current version (12.4), the syntax is (page 249):
-g UnusedPin:{Pullup | Pulldown | Pullnone}
The default setting is
-g UnusedPin:Pulldown
If you want to change this setting from within ISE Project Navigator,  in the Processes pane
  • select the Generate Programming File process
  • right-click and select Process Properties from the pop-up context menu
  • in the Property display level drop-down list (at the bottom of the window), select Advanced
  • Select General Options in the left pane.
  • in the Other Bitgen Command Line Options entry row (right pane), enter the command line options (e.g. -g UnusedPins:Pullup)
-- Bob Elkind
SIGNATURE:
Summary:
Re: Defualt IO states
The HSWAPEN pin detemine whether the IOB has a pullup resistor during configruation and pre-configuration, after that,  unused IO state can be defined by the bitgen option:-g UnusedPin:
Simon
Teacher eteam00
-- Bob Elkind
SIGNATURE:
Summary:
Newbie joseg
Does the HSWAPEN pin have its own default state?  I have a layout where I forgot to connect the HSWAPEN pin on the Spartan 6--trying to use the SelectMAP configuration interface.
Teacher eteam00
HSWAPEN default state before/during config
Each FPGA family may be different on this question.
The information you seek is (for Spartan-6) in UG380, the Configuration User Guide.  HSWAPEN pin has an internal weak pullup (to VCCO_0) before and during configuration.  HSWAPEN is a user I/O after configuration.
- Bob Elkind
SIGNATURE:
Summary:
