Anonymous
Not applicable
Difference between two S6 devices
I am looking for one spartan-6 XC6SLX16 device in CPG196 package. I found these two devices in digi-key. Is there any other significant differences in terms of speed, voltages etc apart from the differences in no. of CLB, RAM bits etc. mentioned in digikey specs?
XC6SLX16-L1CPG196I
http://www.digikey.com/product-detail/en/XC6SLX16-L1CPG196I/122-1767-ND/2339828
XC6SLX4-3CPG196I
http://www.digikey.com/product-detail/en/XC6SLX4-3CPG196I/XC6SLX4-3CPG196I-ND/2339860
And what does L1(in first device part no.) stand for?
vuppala
See below snapshot:
Also see this pdf: http://www.xilinx.com/publications/prod_mktg/Spartan6_Product_Table.pdf
Vinay
vuppala
See below snapshot:
Vinay
Anonymous
Not applicable
Thank you.
