Visitor jackseiko
Differential Signal and LVDS
I need to use differential signal on my application, I wonder that is it possible to use differential signal on serial input/output ports on spartan-3e? or should I use another output interface?
does spartan-3e provide LVDS 350 mV. If it does, could you explain how to use it ?
thanks in advance
Re: Differential Signal and LVDS
You can convert probably any single ended signal into a differential ouput signal by using OBUFDS primitive.
Things to keep in mind:
1. The differential ouput signals must exit only to the top level IOB pads.
2. Choose the proper pin polarity in the constraint file when defining the pins.
I have attached a PDF file to give more info about LVDS standard. For your application, I believe LVDS_25 standard should be good.
Heres an example of converting a single ended standard to a differential ended:
OBUFDS #(
      .IOSTANDARD("LVDS_25") // Specify the output I/O standard
   ) OBUFDS_inst (
      .O(ServoDataToSOCp),     // Diff_p output (connect directly to top-level port) (p type differential o/p)
      .OB(ServoDataToSOCn),   // Diff_n output (connect directly to top-level port) (n type differential o/p)
      .I(Servo_Data)      // Buffer input (this is the single ended standard)
Please let me know if you need any fiurther info.
Shax
OBUFDS #(
   ) OBUFDS_inst (
Shax
Visitor jackseiko
thank you so much. it is helpful :)
Visitor mariasessa
I want drive a device with a signal LVDS, but I have a problem.
With OBUFDS primitive and the configuration i have  VIDIFF=700mV.
How I can obtain a VIDIFF=350mV?
BR,
Maria
Historian
Historian
@mariasessa wrote:
BR,
Maria
is the signal terminated properly?
Visitor mariasessa
Hi bassman,
I think that the signal is terminated properly.
The project is on a Virtex 6, on board ML605.
I use OBUFDS primitive with a signal in Input and a pair of PAD nets in output.
The output is configugured on FMC HPC with daughter board (XM105 debug card).
The output is configured on two pin for LVDS signal (pin p and pin n).
The synthesis runs correctly without error.
With a multimeter, I'm measuring the voltage on this pin, and I obtained a VIDFF of  700mv, not 350mV. Why this?
With this signal i must driver l'input of a camera on camerallink bus (this bus use a signal LVDS).
Now, i can read the LVDS signal from camera how the clock signal.
I'm working without chip national!
BR,
Maria
There are no termination resistors on the FMC-XM105.
Historian
Historian
@mariasessa wrote:
Hi bassman,
Um, this is the Spartan forum, not the Virtex forum.
And you "think" it's terminated properly? Either it is, or it isn't. Verify whether it is or not.
