neelmehta89
Display a counter on an LCD
I want to display an internal "counter" to the LCD on the Spartan 3E starter kit. I am currently being able to print a fixed string, and I am familiar with the basic LCD operation.
To display a counter, the DB7:DB4 are not fixed but dependent on the counter value. So, instead of going through a "case" and finding out what the counter bit is and then using the corresponding bits from CG-ROM and printing it on the LCD, is there a direct/indirect way to display the counter?
Note that I am using verilog as my HDL language and what needs to be printed is a number/counter.
eteam00
Professor
Professor
Let's assume the counter is 8 bits wide, and you want to display the counter's 8-bit value as 2 hexadecimal (range 0-9 + A-F) characters.
  • From Table 4 of the HD44780U data sheet we see that the displayed characters '0'-'9' are represented by character codes 0x30-0x39.
  • From Table 4 of the HD44780U data sheet we see that the displayed characters 'A'-'F' are represented by character codes 0x41-0x46.
  • To each of the 4-bit portions of the 8-bit counter value, add 0x30.  If the result is greater than 0x39, then add another 0x07.
  • The resulting sum is what you should 'send' to the LCD (actually, you are sending it to the HD44780U LCD controller).
Does this make sense?
-- Bob Elkind
SIGNATURE:
Summary:
eteam00
Professor
Professor
-- Bob Elkind
SIGNATURE:
Summary:
neelmehta89
Makes perfect sense. Thanks.
