Does Spartan-6 support the dynamic reconfiguration with ICAP?
The user guide(ug380) of Spartan-6 does not mention that it can write the configuration memory with ICAP. So I want to know if we can rewrite the configuration memory with ICAP.
Thank you!
Advisor
Advisor
Re: Does Spartan-6 support the dynamic reconfiguration with ICAP?
You mean partial reconfiguration? No, it's not supported on the Spartan series.
Advisor
Advisor
Thank you very much!
Multiboot is supported through ICAP. You may want to download sp605 reference design.
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
Hi aher,
I have already marked the "Accept as solution". Thank you for your advice.
