Observer zfima
Double buffering on Spartan3
Hello
I have working system that takes picture and show it on LCD
From list of pictures i can build  play list on PC and send it to FPGA.
Now, i want make double buffering - when one picture shows on LCD, prepare other in 3 blocks of RAM
I read pdf from http://www.datasheetarchive.com/datasheet-pdf/078/DSAE0072579.html, but i didnt know how to do this....
Question - how to do this?
thanks a lot
Observer zfima
Re: Double buffering on Spartan3
Maybe i ask too much, so if someone can, pls give me some direction.... or something
thanks
Historian
Historian
thanks
There's a lot going on here -- you need, at the least, a state machine to handle writing to the buffers, and another which handles reading the buffers and driving the display. (Hint: dual-port.)
This is somewhat complicated but fairly straightforward.
Observer zfima
Thank you for answer
I use 3 blocks of "Simple Dual Port RAM" for R,G and B
Now, i have 17 used blocks from 20, so i have 3 blocks free. So, i use it for implement double buffering.
So, i think i need mux 1 bit control, that every time change output. Something, like in picture:
dbuf
It is good direction of my thought?
thanks
Other solution  for double buffering - increase each buffer twice as much and use MSB of address bus for switching between
memory regions. I use this approach in my last design with DPRAM, but not for Video application.
 -- Regards, Victor
Message Edited by kurgan on 01-12-2010 04:32 AM
