Dual microblaze system
             I am using spartan 6 numato saturn board. I have used it with a single microblaze configured. Now I want to configure dual microblaze system in it. I don't want both of these microblaze to communicate with each other. But instead i want to connect different peripherals to each of these and all these peripherals should work simultaneously.Is it possible to do that? After doing google also I am not getting an idea about how I should write C program for this . Should I generate two different .elf files for these different processor? Should I have different C program for two of  microblaze? The tools I am using are xilinx XPS and Xilinx SDK from EDK.
With Regards
Shalini
Tags (2)
Re: Dual microblaze system
I solved the problem. When exporting dual microblaze system to Xilinx SDK , when creating application project there is an option to enter the processor required microblaze0 or microblaze1. There you can give option as desired and generate two elf for different microblaze.
With Regards
Shalini
still I have not figured out how to do it. Please help.
I managed to do a .xps project with these , but when I export to SDK I dont see second microblaze and it's peripherals anywhere in the project. Attached is XPS project.
With regards
Shalini
With Regards
Shalini
