Visitor bkishore81
Dynamically changing FPGA Bank IO voltage
Is it OK to change the FPGA bank voltage dynamically from one higher voltage to lower voltage (say 3.3V to 1.8V) and viceversa? If so, what will be the behaviour of the IOs when the corresponding bank voltage is set to change dynically?
Any thoughts?
Thanks and regards.
Voyager
Voyager
Re: Dynamically changing FPGA Bank IO voltage
Do you use Spartan3/6? Vcco of bank2 must be supplied all the time. If bank2's Vcco is lost, configuration data will be lost too. For other bank, you can change Vcco dynamically. The glitch I think will be on IO.
Visitor bkishore81
The plan is to use Spartan 3 FPGA.
Instructor
Instructor
As suggested, stay away from banks used during configuration.  Also look through the
users guide to check on the behavior of individual IO standards.  Some input standards
are not affected by Vcco.  All output standards are affected.  LVCMOS inputs use an
input threshold based on Vcco.  LVCMOS outputs drive to Vcco when high regardless
of whether the Vcco matches the assigned standard.  If you use a Vcco other than that
specified in the iostandard, i.e. LVCMOS33 with Vcco = 1.8V, the drive capability will
not match the standard.  Generally drivers are stronger with higher Vcco, so LVCMOS33
12 mA will only drive a fraction of 12 mA when the Vcco is lowered to 1.8V.  You can
get an idea of the ratios by looking at the maximum available drive strength for each
voltage standard.
HTH,
Gabor
-- Gabor
