07-26-2017 05:45 AM
Hi to all.
I would like to know what I exactly need to load a bitstream + C-code from an external flash memory to the FPGA after power up the FPGA.
I am using a custom board with Spartan-6 LX45T. Data must be retained after power down and power up FPGA so we use a flash memory (S25FL256S by Spansion). This flash memory is not attached to JTAG chain, and it is not supported by Spartan 6 to carry out indirect programming. So I have to use a specific software to load .bin and .srec files into flash (my system is composed of one Microblaze + Logic). This is done by Ethernet (UDP), and apparently, the process is correctly done. But after power up again FPGA, nothing is loaded from Flash.
I am a newbie with this so, sorry if I say something stupid.. During design phase I have not required to save the code on the Flash, but now I need it , and it seems that it is not as easy as I thought. So I would need a little explanation about what I would need to carry this out. So these are my doubts:
1. Do I need a Microblaze system with an AXI Quad SPI Core to load data from Flash after power it up??
2. If yes, how could it be possible to load a bitstream without a Microblaze system (only VHDL code)??
3. If an AXI quad SPI core is required, should it be configured as Master or Slave?? I have tried as Master and I get this error during synthesis (Error on EXT_SPI_CLK signal):
Why this external SPI clock should be connected??? I am only using the following signasl which are part of the SPI communication. Do i need something more??:
4. Is the use of "special" primitives like startup_spartan6 required to get what I want??
5. Do I have to configure linker script in a "special" way to allow boot from Flash??
Many thanks in advance for your support.
Regards.
08-07-2017 01:31 AM
Hi @iguo.
Many thanks for your answer. It seems there is a HW problem in the board. Flash memory has been correctly loaded on similar boards so it can work with Spartan 6 family, but i am looking for HW problems because it is not working on this board.
Many thanks for your answer. I close the post.
Regards.
08-01-2017 08:09 PM
08-07-2017 01:31 AM
Hi @iguo.
Regards.
