FIFO
HI everybody,
                        I have a query on FIFO generation, Please guide me...
I has to generate a FIFO which can store a 1024 locations and also while the next block to the FIFO, FFT reads the data from FIFO then a new samples will arrive into that FIFO. I have selected the wire depth of 1024 but while i was selecting the  "Single Programmable Full threshold constant"  and the i have selected "Full Threshold Assert value" , which i want to set it as 1024 ,but its range is 3 to 1021 which 3 locations less than what i needed.   Can anybody guide me ,please...............
        Shariff.
Instructor
Instructor
Shariff,
Why not decode the data_count output from the FIFO?
The LogiCore FIFO datasheet (DS317) explicitly mentions that there are limitations on the range of programmable threshold levels.  These limits may be based on available logic (for the Built-In FIFO) or logic/pipeline delays (if the threshold level is too close to the size (or "full" level) of the FIFO.  This is merely speculation on my part.
-- Bob Elkind
SIGNATURE:
Summary:
Advisor
Advisor
If you only need to know when the 1024 word FIFO is completely full, don't bother with the programmable threshold - use the "full" signal.
Alternatively, if your samples arrive constantly, could you use the streaming FFT interface and avoid the need for a FIFO?
Thanks for your reply,
                          But i am using FIFO and then FFT (Pipe line streaming).I want ot use FIFO which can store 1024 samples or more.I have generated it from xilinx core generator but with 1021 samples lenght.So please tell me how can i generate 1024 or more samples from it. Is it just by selecting the write width to 2058, i did so, then it has allowed me to select the 2053 samples?is it correct way or any other way.
                                                shariff
                        I like to know is that a better option to take an datacount output, As while the FIFO has reached 1024 then FFT starts reading it and simultaneously next 1024 samples may also appear in the FIFO, soit might be little more than 1024, i cant expect exact value.it will be more than 1024 samples.After storing 1024 samples then with the help of Programmable flag FFT can start read from it ,mean while FIFO stores next coming saples,Ok. I am using FIFO and then FFT (Pipe line streaming).I want ot use FIFO which can store 1024 samples or more.I have generated it from xilinx core generator but with 1021 samples lenght.So please tell me how can i generate 1024 or more samples from it. Is it just by selecting the write width to 2058, i did so, then it has allowed me to select the 2053 samples?is it correct way or any other way.
                                                shariff
Instructor
Instructor
You can configure the FIFO as large as the target FPGA and the FIFO wizard will support.
If you need a FIFO to store 1236 samples, a larger FIFO (2048 samples, for example) should not cause any problems whatsoever.  Your write logic can fill the FIFO to whatever depth you would like to configure.
-- Bob Elkind
SIGNATURE:
Summary:
Thanks for your reply, i will try it....
If the sample storing logic (i.e. writing to the FIFO) and the FFT (reading from the FIFO) are using the same clock, a dual port (DP) RAM should be all you need. You can divide a 2048-word DP RAM into two 1024-word ping-pong buffers and have the writing and reading logic work on the buffers alternatively.
                                                shariff
Cheers,
Jim
@08220158 :   hii even my project is the same...but i m doing radix2 burst i/o.. can u tell me hw did u get away with the problem? if possible can u share fifo code... plz its urgent.. Thanks
hello i too need the same design help me out its urgently needed
