Observer xiaochh
FMC of sp601
hello,everyone.
we know that Spartan-6 FPGA SP601 board has one FMC-LPC connector ,and we can extend our applications to video、audio、and so on ,but where to find the FMC daughter cards ?
  I have read the document 《I/O Design Flexibility with the FPGA Mezzanine Card (FMC)》 ,but only to find  FMC-Video Mezzanine Board, where to find FMC-Audio Mezzanine Board or other application cards.
  thanks sincerely!
Tags (4)
Re: FMC of sp601
The FMC interface opens up a number of possibilities for companies to create peripheral cards, but at this point in time there are not many available.  This will change over the next couple of years.
Note: The FMC interfaces used on the Spartan-6 and Virtex-6 boards have a fixed IO supply (VADJ) of 2.5V.  FMC cards that have not been designed to support a range of VADJ levels will not be compatible.  This includes the FMC-VIDEO card from the Spartan-3A kit that requires VADJ to be 3.3V
Re: FMC of sp601
Observer xiaochh
Re: FMC of sp601
    Thank you very much, mcgett, your information is very important for our project .
    So ,if we want to extend applications with FMC daugher card on SP601, what we can do is just to wait ....? Or ,is there any other way?
    Thanks!
Re: FMC of sp601
You could always design and build a FMC with the components that you need.
