Visitor mark_boden
FPGA DONE Pin
I was wondering someone could help me, I am looking to have some indication that the FPGA has finished programming. The data sheets says not to drive the pin directly with an LED. Any recommendations on how to attach an LED to this pin to indicate that the program has been succesfully loaded.
Many Thanks
Mark
Everything Should Be Made as Simple as Possible, But Not Simpler
Teacher eteam00
Re: FPGA DONE Pin
Any of the following answers should work:
  • Drive an LED from a 'spare' IO pin.  In your source code, output a steady state LOW on this pin, which will drive the LED cathode LOW and turn it on.  Until the FPGA is configured, the LED will be off.
  • Buffer the DONE pin with a logic-level nFET (e.g. BSS138 or FDN337N), and use the FET to drive the LED cathode LOW.
  • Instead of providing an LED which indicates DONE, connect the DONE signal to the LED cathode.  The LED will indicate NOT DONE rather than DONE.
-- Bob Elkind
SIGNATURE:
Summary:
Teacher eteam00
Re: FPGA DONE Pin
-- Bob Elkind
SIGNATURE:
Summary:
Instructor
Instructor
Re: FPGA DONE Pin
I vote for the first approach.
In my humble opinion, adding an LED to the DONE signal is a waste of a good LED.  Once you've debugged your configuration issues, you'll be very glad to have an LED that can be used to indicate other debug information, like blinking to indicate that the clock system is running, etc.
-- Gabor
Teacher eteam00
Re: FPGA DONE Pin
I agree with Gabor.
A link to this thread has been added to the New Users forum README thread.
-- Bob Elkind
SIGNATURE:
Summary:
Visitor mark_boden
Re: FPGA DONE Pin
Thanks again for all the help guys
Visitor cleonjones
Re: FPGA DONE Pin
Using another pin to drive an LED is not an ideal solution - it uses up a pin, and only works if the code in the FPGA is properly driving it (e.g. if you load an image that has forgotten to set this pin, you may spend a lot of time wondering why the "DONE" signal is not asserting).
It's better to use the actual DONE signal, and there's no need to use a transistor.
Connect DONE to 3.3V via a pullup resistor of 330 Ohms.
Connect DONE also to the anode of an LED (just not blue or white, as the voltage drop is too high).
Connect the cathode of the LED to another 330 Ohms, and other side of that resistor to ground.
During configuration the DONE signal is driven low and the LED is off. DONE will sink about 10mA through the pullup, benign.
After configuration DONE tri-states, and the LED will turn on, powered by 3.3V through 660 Ohms.
The drop across a typical red or green LED is about 1.8V, so the LED gets about 2mA of on current.
The purpose of the lower resistor to ground is so that the voltage level of the DONE maintains a valid 'high' level, about 2.6V, in case other logic wants to read this. If nobody needs to read the DONE level then you don't even need this resistor (connect cathode directly to ground).
We have used this circuit for years.
