Fast external RAM like internal Block RAM
 In a project I am running out of Block RAM in the Spartan 6. The cpu reads and writes to this block RAM at 100MHz. I want to keep this speed and use external RAM. I am looking at synchronous RAM made by Cypress that can run up to 250MHz (for the smallest delay). Is this the way to go for external RAM? Does anyone have experience with this issue?
Instructor
Instructor
Re: Fast external RAM like internal Block RAM
If it's just for random CPU access, no DMA, no dual-port, etc.  Then probably async (if you can find it
fast enough) or passthrough sync SRAM would be the best bet.  By the way, I thought a 6502 tops
out at 64 KB of RAM (512 Kbits).  Even a fairly small S6 (but not the smallest) has that much BRAM.
What part are you using?
-- Gabor
-- Gabor
Instructor
Instructor
It depends on a lot of things.  Any external memory will have more latency than the internal
block RAM.  If you're writing data in large blocks and then reading out in large blocks like
for video buffering, you might find that DDR2 or DDR3 SDRAM is actually the fastest option,
although it will have higher latency than SRAM.  There are also high-speed pipelined SRAM's
which work well for large or small data blocks, but have one or more cycles of turn-around
latency when switching between write and read.  This is still small compared to DDR2
SDRAM.  Depending on your application, you might be able to use internal BRAM to help buffer
the external writes and reads to reduce the frequency of read / write switching.
Maybe with a little more understanding of your application someone could recommend
an appropriate memory type.
-- Gabor
-- Gabor
Thanks for your reply Gabor.
A 16bit cpu core is using the Block RAM as a true Random Access memory. It's a modified 6502 retro type core. Depending on the code written, the core reads or writes memory.. I noticed there are 2 kinds of synchronous RAM. The pipelined and passthrough. But I have no experience with any external memory  but asynchronous, so I'm not sure... But I do know I am running out of BlockRAM.
Historian
Historian
You could use a fast asynchronous SRAM.
Hi Bassman,
Not 100% sure I could. I need to make sure this works as I will be drawing up PCB plans for a memory board. Since I know the core works perfectly well with the Spartan 6 Internal Block RAM, I wish to use the same type synchronous memory for external program storage. Plus, these memories go 2.5 times faster than the fastest ASynchronous RAMs I've seen @10ns, in the size I need.
Instructor
Instructor
-- Gabor
-- Gabor
I'm using an LX9 144-pin QFP. This modified core has a double wide data bus and double wide address bus, so it can address a full 4GB worth. If you're interested, there is more info on 6502.org in the Programmable Logic section. I am very active there as ElEctric_Eye and most of us favor Xilinx products.
BTW thanks for the help, I'll start experimenting!
Instructor
Instructor
Another point.  I realize that part of the appeal of processors like the 6502 is the
deterministic cycle timing, so maybe going to a non-uniform memory stucture
will be a problem depending on what the core is doing.  Another option may be
to implement a cache as in the MicroBlaze when using external DRAM.  Of course
that gets away from the K.I.S.S. approach...
-- Gabor
-- Gabor
Well, there is one of our members, actually the creator of the original 8bit core we modified, who is well versed in Verilog and has had experience using the BRAM as a cache for SDRAM in his projects. I don't like dynamic ram. I prefer to keep it simple and fast. And so I figure if I can get an external memory (passthrough synchronous RAM) to act as the BRAM, then I should be good I would think...
Actually, the synchronous RAM parts I am looking at from Cypress advertise NoBL=No Bus Latency
Historian
Historian
So, read the data sheet and work out the timing, and see if it works in your application.
Voyager
Voyager
This Xilinx Spartan-3 kit can help  Spartan-3 User Guide ? Check page 11.
Spartan-3 have microblaze connected with 2 M external memory without a memory controller, use SRAM. Maybe you can adapt the scheme for 6502.
secureasm
