Newbie xilinx_raju
Fifo generator IP core: fault in reading
I have used the Fifo generator IP core with independent read and write clock domain. I first write 100 words into the fifo and then read 100 back. But on reading i started getting data from the fourth location, not the first as should be. Is this IP core faulty or there is some other better way to use it.
Teacher rcingham
Re: Fifo generator IP core: fault in reading
Which FPGA?
What versions of ISE and IP?
What are the clock frequencies?
Is this in simulation? If so, which simulator?
Can you post waveform diagrams?
"If it don't work in simulation, it won't work on the board."
Instructor
Instructor
If this is simulation, did you wait 100 ns for global set/reset to de-assert before starting to write
your 100 words?
-- Gabor
