urodacus
Generating a clock - SPI communication
I'm quite new at this and I had some questions.
For a project, i'm linking a Spartan 6 (SPI master) to another board (SPI slave).
I guess I'll have to code how to manage MISO, MOSI and CS but I don't know how I'll handle the clock.
Should i use a quartz (oscillator) or can the FPGA "make" the clock at a desired frequency?
Thanks for the help,
Uro.
chapman
I have provided a PicoBlaze reference design that can access an SPI Flash device. In this case PicoBlaze generates clock pulses as and when they are required. Whether you just refer to the documentation and source code with all its comments to find out how SPI works or adopt PicoBlaze to implement the SPI Master signalling and slave protocol that you need (all in less than 30 Slices) I hope you find it a useful reference.
https://www.xilinx.com/products/intellectual-property/picoblaze.html
See 'design Files' tab and download the 'KCPSM6' package. In the zip file you will find a 'Reference Designs' folder and your initial interest will be the design in the 'SPI' folder.
Ken Chapman
Principal Engineer, Xilinx UK
u4223374
Advisor
Advisor
@urodacus The FPGA can't generate clocks without a reference. Virtually any FPGA board you can find will have an oscillator already installed to provide a clock source.
Once you've got access to one clock, the FPGA clock management system can generate new clocks derived from that one at whatever frequency you want.
urodacus
Thank you for providing me this.
This is not for a SPI flash (though I'll need a SPI flash) but from what i understood, i can indirectly program it through FPGA with JTAG, isn't it?
But I may use it even though that is not a SPI flash (it's an embedded TCP/IP ethernet controller)
The FPGA has an internal clock, right?
I only used FPGA when they already were on boards (school projects, etc.). It's my first time using one without being on a board
urodacus
By "without being on a board", I mean that i do the board
kkn
Hi Urodacus,
you can use the startup primitive to drive out the configuration clock post configuration.
https://www.xilinx.com/support/answers/33899.html
But in spartan-6 the CCLK pin is multipurpose pin, which means after configuration this pin will be user IO and startup primitive will not help here. check the above solution record explaining about this scenario for spartan devices
--Krishna
urodacus
@kkn wrote:
Hi Urodacus,
--Krishna
I'm sorry but what you just said isn't clear to me.
I don't understand your reply (Startup primitive, etc.)
kkn
you can check the spartan-6 libraries guide for details on startup primitive(from page 314)
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/spartan6_hdl.pdf
The AR I pointed to you explains how you can use startup primitive to drive the configuration clock after configuration in CCLK pin.
configuration clock here is the internal oscillator which is used during master configuration's and this frequency is set in the bitgen settings
urodacus
"This is not applicable for Spartan devices as the CCLK pin is User I/O after configuration and is not a dedicated pin."
That means I can't use it, right?
kkn
yes, you cannot drive out the configuration clock post configuration on the cclk pin in spartan-6 device by using the startup primitive.
Do you have a system clock for the fpga? i.e. how is your design clocked inside the fpga?
urodacus
That's what I was asking in a previous post, I don't know if the FPGA has an internal clock, does he have one or do I have to use an oscillator or smth?
chapman
It is normal to have at least one external clock source to provide a known timing reference. However, the STARTUP_SPARTAN6 primitive has a CLKMCLK output pin that provides an internal oscillator of approximately 50MHz. This is described in UG380.
The PicoBlaze reference design that I suggested to you earlier is an example of an SPI Master. It shows how SPI signals can be generated and how the protocol for a device can be implemented. Yes, the reference design is for an SPI Flash devices but as a 'reference' it should be useful.
Ken Chapman
urodacus
Yes, I didn't know that and always thought that the FPGA had an internal oscillator.
I'll use an external oscillator but I guess there is a maximal frequency and that sort of thing, can someone point to me where I can see that sort of things?
Thank you for the PicoBlaze design, I'll look it up and come back later if I have question about it !
