Help MIG_39 on LX75
I try to implement memory controller on Spartan 6 xc6lx75-3csg484 but it doesn’t work for the moment.
I have NANY- NT5CB64M16FP it’s 128mb ddr3 Sdram.
I’m looking for one example which works.
Think a lot.
Re: Help MIG_39 on LX75
Please go through UG388 for list of Supported memory devices.
I think Nanya is not hardware evaluated by Xilinx so we cannot assure that it works.
But you have not mentioned what is not working.
As you cannot genearte MIG for Nanya part you would have use custom part, please check if all the timing parameters were properly set as per nanya datasheet.
Go through Debugging section of UG and figure which stage of calibration is failing and if any data errors
Make sure your clocking and reset circuitry is proper and board layout guideliness were met
 Go through below master AR and follow the steps outlined.
http://www.xilinx.com/support/answers/40775.html
Hope this helps
Vanitha
Thinks, I followed your help. now MIG are working.
Now my controller MIG
Input I have 8 bits data and 7 bits addr.
The memory returns always FF don’t understand
My code is bellow
You mean to say default MIG is working but you see data errors with your own traffic?
If yes please follow the command, write and read  timing diagrams in UG388 and cross check against your signals.
If this is in HW I would sugget you to verify in simulation.
