How do I get MicroBlaze to program it's own SPI?
Does anyone have the experience with MultiBoot on Spartan-6
where the MicroBlaze receives a bit file from a remote location
and has to program its own SPI ? The golden version is programmed
into the SPI at the factory but new versions are programmed into
the SPI in the field (whithout iMPACT) just the built in MicroBlaze.
Jacob
Several of the important concepts can be leveraged from here:
http://www.xilinx.com/support/documentation/application_notes/xapp1020.pdf (Post-Configuration Access to SPI Flash Memory with Virtex-5 FPGAs)
 [note that S6 has its own primitive STARTUP_SPARTAN6 described in its Library Guide]
http://www.xilinx.com/products/boards/sp601/reference_designs.htm
http://www.xilinx.com/products/boards/sp605/reference_designs.htm
 [see the multi-boot designs]
bt
Historian
Historian
Jacob
SPI is an interface, not a device.
bt
The basic principle is very easy: make sure your board allows to access the SPI flash from the FPGA. For Spartan-3 the SPI interface pins can become regular pins after configuration so that's easy (don't know about Spartan-6). Add a SPI master to your microblaze design. Use something like promgen to convert the bitfile in an easy format such as hex and push that to the FPGA for programming in the flash. You just need a few simple SPI flash command such as erase, sector erase, bulk write and bulk read.
Cheers,
Johan
Avnet has a reference design for the 1800A board based on EDK 9.2 that does exactly this.  The new bitstream comes over ethernet, but it could easily be any other communication link to which the FPGA has access.
www.em.avnet.com/spartan3a-dsp --> Support Files & Downloads --> > S3A1800DSP Serial Flash Bistream Update over Ethernet
I'm currently working on updating this to 11.4 as the SPI peripheral drivers have changed since 9.2.  Hope to have something new posted within a couple weeks.
Bryan
Hi Bryan,
This design is exactly what I need, but I need it to work with 12.3 and the current driverset that SDK generates.  DId you have time to update your design to 12.3 (or 11.4) ?
Thanks in advance.
Steven
I did update this design to 11.4, although I didn't use SDK.  It's listed at the same location given above, but look under  ISE Design Suite 11.4.
Bryan
Thanks Bryan,
I will take a look at it.
Steven
