sniperchild
How do you erase the entire ISF in Spartan-3AN
I have a Spartan-3AN XC3S400AN
I am booting from internal flash.
If I connect Impact [14.7], without assigning a config file I have no option to erase.
If I assign a config file and select erase, only the first half of flash is erased.
How do I issue a full chip erase?
sniperchild
Solution is in this AR
http://www.xilinx.com/support/answers/36308.html
Erase -o is used for full chip erase.
Erase -o -p 1 is the format to get impact to accept it in batch mode
sniperchild
