Newbie shakeel
How to connect RC SERVO with Spartan 3E
 how can i connect (interface) a RC SERVO Motor with Spartan 3E
i already  have a Verilog Code of it.just want to know about the Conneetion between Servo motor and fpga.
Instructor
Instructor
Re: How to connect RC SERVO with Spartan 3E
Hey, this sounds cool.  Do we get to pick any motor, or do you have specific motor in mind?  If you do, post a link to the motor's datasheet !
Do you already have the circuit board designed?  The voltage supplies you have hooked up to the FPGA might make a difference.
-- Bob Elkind
SIGNATURE:
Summary:
Historian
Historian
I would use wires. Carbon nanotubes are somewhat expensive and difficult to source.
The SERVO's signal is like this:
(Please see the attachment)
Teacher eilert
Hi Bob,
a RC-Servo is a digitally controlled device not to be confused with a common servo motor.
(The OP sloppily used the second term at the end of his post, so he's to blame)
The controll signal is a 50Hz PWM signal of 1.5ms duration with +/- 0.5ms modulation.
(See binx reply with the timing diagramm)
Have a look at this  page for a nice detailed description:
http://www.rcmodelreviews.com/howservoswork.shtml
The only thing that might actually be neeeded is a 5V level translator to drive the RC-Servo control signal from the 3.3V FPGA I/O. Some 74HCTxxx line driver or logic device would be sufficient and convenient.
  Eilert
If you have a development board with Pmod expansion, you can use a Pmod from Digilent.  Here's an example of this with a Spartan-6 board using 3.3V FPGA I/O.
  http://www.em.avnet.com/servopmod
Bryan
Visitor 78692
i have spartan 3e and want to rotate servo hitec motor hs-422 ... i do not have the jtag cable ,.... on which pin i should give the pwm signal then........can i give it on j2 or j4???
