How to declare two bit input in UCF of verilog
This is my code
module alu2bit(aluout,result,zero,one,two,three,four,five ,six,seven,eight,nine,a,b,select);
output [3:0] aluout,result; // the result
output [3:0] zero,one,two,three,four,five,six,seven,eight,nine;
input [1:0] a,b; // input a and b
input [1:0] select;
reg [3:0] aluout,result;
reg [3:0] zero,one,two,three,four,five,six,seven,eight,nine;
always@(a or b)
begin
case (select)
2'b00:aluout=a+b; // For addition of two bits
2'b01:aluout=a-b; // For addition of two bits
2'b10:aluout=a*b; // For multiplication of two bits
endcase
if (aluout==4'd0) result=zero;
else if (aluout==4'd1) result=one;
else if (aluout==4'd2) result=two;
else if (aluout==4'd3) result=three;
else if (aluout==4'd4) result=four;
else if (aluout==4'd5) result=five;
else if (aluout==4'd6) result=six;
else if (aluout==4'd7) result=seven;
else if (aluout==4'd result=eight;
else if (aluout==4'd9) result=nine;
else result=zero;
end
endmodule
I want my LEDs to glow as per my result. how can i tell UCF about my two bit input data a and b
U can also give comments to refine my code
Re: How to declare two bit input in UCF of verilog
You forgot the reg.  This works for me.  You will have to assign the one two three etc to the pin in the ucf.
output reg zero;
output reg one;
output reg two;
output reg three;
output reg four;
output reg five;
output reg six;
output reg seven;
output reg eight;
output reg nine;
input [1:0] select;
always@(*)
begin
case (select)
endcase
zero <= (aluout==4'd0) ? 1'b1:1'b0;
one <= (aluout==4'd1) ? 1'b1:1'b0;
two  <= (aluout==4'd2) ? 1'b1:1'b0;
three <= (aluout==4'd3) ? 1'b1:1'b0;
four <= (aluout==4'd4) ? 1'b1:1'b0;
five <= (aluout==4'd5) ? 1'b1:1'b0;
six  <= (aluout==4'd6) ? 1'b1:1'b0;
seven <= (aluout==4'd7) ? 1'b1:1'b0;
eight <= (aluout==4'd8) ? 1'b1:1'b0;
end
endmodule
-R
Mentor awillen
Mentor
From your other posts I can see that you already know how to write constraints for you in- and output signals. If you have a vector, like a, then you can address the individual bits like this:
NET "a<0>" LOC=...
As for your code:
  • consider using a case statement instead of nested if-then-else
  • use always @(*) instead of always @(a or b), except if you have very good reasons (which you don't, in this case) – especially since you forgot a signal here (select)
Adrian
Please google your question before asking it.
If someone answers your question, mark the post with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left).
I am unable to make my bit file it is giving error message.
ERROR:ConstraintSystem:59 - Constraint <SLEW = SLOW |> [alu2bit.ucf(1]: NET
"eight" not found. Please verify that:
1. The specified design element actually exists in the original design.
2. The specified object is spelled correctly in the constraint source file.
This error is from one to eight.
My Code is
module alu2bit(aluout,result,a,b,select);
output [3:0] aluout;        // the result
output [3:0]result;
input [1:0] select;
always@(a or b)
begin
case (select)
endcase
if (aluout==4'd0) result=zero; // no LED will glow
else if (aluout==4'd8) result=eight;
else result=zero;
end
endmodule
My UCF is
NET "a<0>" LOC = "L13" | IOSTANDARD = LVTTL | PULLUP ; //for a input
NET "a<1>" LOC = "L14" | IOSTANDARD = LVTTL | PULLUP ; //for a input
NET "b<0>" LOC = "K17" | IOSTANDARD = LVTTL | PULLDOWN ; // for b input
NET "b<1>" LOC = "D18" | IOSTANDARD = LVTTL | PULLDOWN ; // for b input
NET "select<0>" LOC = "H18" | IOSTANDARD = LVTTL | PULLUP ; //for a input
NET "select<1>" LOC = "N17" | IOSTANDARD = LVTTL | PULLUP ; //for a input
NET "one" LOC = "F12" | IOSTANDARD = LVTTL | SLEW = SLOW | DRIVE = 8 ;
NET "two" LOC = "E12" | IOSTANDARD = LVTTL | SLEW = SLOW | DRIVE = 8 ;
NET "three" LOC = "E11" | IOSTANDARD = LVTTL | SLEW = SLOW | DRIVE = 8 ;
NET "four" LOC = "F11" | IOSTANDARD = LVTTL | SLEW = SLOW | DRIVE = 8 ;
NET "five" LOC = "C11" | IOSTANDARD = LVTTL | SLEW = SLOW | DRIVE = 8 ;
NET "six" LOC = "D11" | IOSTANDARD = LVTTL | SLEW = SLOW | DRIVE = 8 ;
NET "seven" LOC = "E9" | IOSTANDARD = LVTTL | SLEW = SLOW | DRIVE = 8 ;
NET "eight" LOC = "F9" | IOSTANDARD = LVTTL | SLEW = SLOW | DRIVE = 8 ;
Plz help me.
I want my eight LEDs to glow with eight different math operation result
Teacher eteam00
Is "eight" the name of a pin, or the name of a 4-bit variable?
Is "eight" an input or an output?  If it's an output, where is a value assigned to "eight"?
SIGNATURE:
Summary:
The problem is not with eight only,it is from one to eight.
ERROR:ConstraintSystem:59 - Constraint <NET "one" LOC = "F12" |>
   [alu2bit.ucf(11)]: NET "one" not found.  Please verify that:
ERROR:ConstraintSystem:59 - Constraint <IOSTANDARD = LVTTL |> [alu2bit.ucf(11)]:
ERROR:ConstraintSystem:59 - Constraint <SLEW = SLOW |> [alu2bit.ucf(11)]: NET
ERROR:ConstraintSystem:59 - Constraint <DRIVE = 8 ;> [alu2bit.ucf(11)]: NET
ERROR:ConstraintSystem:59 - Constraint <NET "two" LOC = "E12" |>
   [alu2bit.ucf(12)]: NET "two" not found.  Please verify that:
ERROR:ConstraintSystem:59 - Constraint <IOSTANDARD = LVTTL |> [alu2bit.ucf(12)]:
ERROR:ConstraintSystem:59 - Constraint <SLEW = SLOW |> [alu2bit.ucf(12)]: NET
ERROR:ConstraintSystem:59 - Constraint <DRIVE = 8 ;> [alu2bit.ucf(12)]: NET
ERROR:ConstraintSystem:59 - Constraint <NET "three" LOC = "E11" |>
   [alu2bit.ucf(13)]: NET "three" not found.  Please verify that:
ERROR:ConstraintSystem:59 - Constraint <IOSTANDARD = LVTTL |> [alu2bit.ucf(13)]:
ERROR:ConstraintSystem:59 - Constraint <SLEW = SLOW |> [alu2bit.ucf(13)]: NET
ERROR:ConstraintSystem:59 - Constraint <DRIVE = 8 ;> [alu2bit.ucf(13)]: NET
ERROR:ConstraintSystem:59 - Constraint <NET "four" LOC = "F11" |>
   [alu2bit.ucf(14)]: NET "four" not found.  Please verify that:
ERROR:ConstraintSystem:59 - Constraint <IOSTANDARD = LVTTL |> [alu2bit.ucf(14)]:
ERROR:ConstraintSystem:59 - Constraint <SLEW = SLOW |> [alu2bit.ucf(14)]: NET
ERROR:ConstraintSystem:59 - Constraint <DRIVE = 8 ;> [alu2bit.ucf(14)]: NET
ERROR:ConstraintSystem:59 - Constraint <NET "five" LOC = "C11" |>
   [alu2bit.ucf(15)]: NET "five" not found.  Please verify that:
ERROR:ConstraintSystem:59 - Constraint <IOSTANDARD = LVTTL |> [alu2bit.ucf(15)]:
ERROR:ConstraintSystem:59 - Constraint <SLEW = SLOW |> [alu2bit.ucf(15)]: NET
ERROR:ConstraintSystem:59 - Constraint <DRIVE = 8 ;> [alu2bit.ucf(15)]: NET
ERROR:ConstraintSystem:59 - Constraint <NET "six" LOC = "D11" |>
   [alu2bit.ucf(16)]: NET "six" not found.  Please verify that:
ERROR:ConstraintSystem:59 - Constraint <IOSTANDARD = LVTTL |> [alu2bit.ucf(16)]:
ERROR:ConstraintSystem:59 - Constraint <SLEW = SLOW |> [alu2bit.ucf(16)]: NET
ERROR:ConstraintSystem:59 - Constraint <DRIVE = 8 ;> [alu2bit.ucf(16)]: NET
ERROR:ConstraintSystem:59 - Constraint <NET "seven" LOC = "E9" |>
   [alu2bit.ucf(17)]: NET "seven" not found.  Please verify that:
ERROR:ConstraintSystem:59 - Constraint <IOSTANDARD = LVTTL |> [alu2bit.ucf(17)]:
ERROR:ConstraintSystem:59 - Constraint <SLEW = SLOW |> [alu2bit.ucf(17)]: NET
ERROR:ConstraintSystem:59 - Constraint <DRIVE = 8 ;> [alu2bit.ucf(17)]: NET
ERROR:ConstraintSystem:59 - Constraint <NET "eight" LOC = "F9" |>
   [alu2bit.ucf(18)]: NET "eight" not found.  Please verify that:
ERROR:ConstraintSystem:59 - Constraint <IOSTANDARD = LVTTL |> [alu2bit.ucf(18)]:
ERROR:ConstraintSystem:59 - Constraint <SLEW = SLOW |> [alu2bit.ucf(18)]: NET
ERROR:ConstraintSystem:59 - Constraint <DRIVE = 8 ;> [alu2bit.ucf(18)]: NET
I just want to tell the kit that if result is one, LED1 should glow
if the result of ALU is 2, then LED 2 should glow.
Something is wrong in my code.
I am using one two ...... till eight just to tell the kit
Teacher eteam00
You didn't answer my questions.
Answer the questions for "eight" and you will also have the answers for zero through seven.
SIGNATURE:
Summary:
I have declared one to eight as 4 bit variable
They are neither input ,nor output
they are just registers.
I also tried to declare themas registers but problem still exists
Teacher eteam00
Where are these variables assigned a value?
Is there an entry for "eight" in your .UCF file?  If so, what does that entry mean?
-- Bob Elkind
SIGNATURE:
Summary:
Actually what i want is that if result is one then LED F12 should glow and so on.
plz tell me solution i m tired now to resolve the issue
Teacher eteam00
I'm tired also.  Get some sleep, we'll pick it up when you're back and ready for action.
SIGNATURE:
Summary:
Historian
Historian
The solution is to get a job outside of the electronics field.
Mentor awillen
Mentor
For f**k's sake, read what Bob said! Do you think he's writing just to get his post count up?
Those questions are crucial to your problem. Think about them. Try to answer them. If you can't answer them, then say so, but don't just skip over them.
Teacher eteam00
You mean I'm not?
The fellow has been working hard on this all weekend long, and he's frazzled.  That can be fixed.
- Bob
SIGNATURE:
Summary:
I think this is what you're looking for:
output reg  zero,one,two,three,four,five,six,seven,eight,nine;
set zero to eight to zero in the beginning of your loop.
else if (aluout==4'd1)  one <=1'b1;
else if (aluout==4'd2)  two <= 1'b1;
or alternate
one <= (aluout==4'd1) ?1'b1:1'b0;
 two <= (aluout==4'd2)  ?1'b1:1'b0;
-R
awillen, I am new in this field.
I am trying for last 2 hours but i have failed
when ever i get solution for question i automatically accept it.
Plz help me for this problem
I am very sorry to read what
Teacher eteam00
The error messages are telling you that you defined some pins in the .UCF file, but no such pins exist in your design.
Does that make sense to you?
-- Bob Elkind
SIGNATURE:
Summary:
Respected Sir, yes that i have understood but all i want is
" i want to have multiplication operation on a and b which are two bits each.
I want to choose the select operation of + - and X by switches of kit
then if the result is 1, LED 1 should glow
if result is 2 other LED should glow
and so on.
There is somoe mistake in my verilog Code.if somebody can send me solution then it is ok otherwise i am totally exhasted now.
Mentor awillen
Mentor
Don't worry, we really want to help you, and it doesn't matter that you're new. You can ask as many beginner's questions as you want, and nobody will think bad about you.
However, just as we have patience with you, you need to have patience with us. That means that you have to carefully read our posts, and if there is something you don't understand, then please ask! And if we ask you something, then either because
  1. we need this information, or
  2. the question is supposed to give you a hint: (i.e., you have to think about it, and just being able to answer it brings you one step closer to the solution)
So don't despair, get some rest, carefully read everything in this post again, and then we'll solve your problem step by step.
That's just my signature. It is automatically added to each of my posts and didn't refer specifically to you.
That is absolutely not what I have written. I was refering to Bob, not to you.
Teacher eteam00
SIGNATURE:
Summary:
Sir roym  this concept is also not working
module alu2bit(aluout,result,a,b,select,zero,one,two,three,four,five,six,seven,eight,nine);
output [3:0]result;
input [1:0] select;
output zero,one,two,three,four,five,six,seven,eight,nine;
always@(a or b)
begin
case (select)
endcase
if (aluout==4'd0) zero<=1'b0; // no LED will glow
else if (aluout==4'd1) one<=1'b1;
else if (aluout==4'd2) two<=1'b1;
else if (aluout==4'd3) three<=1'b1;
else if (aluout==4'd4) four<=1'b1;
else if (aluout==4'd5) five<=1'b1;
else if (aluout==4'd6) six<=1'b1;
else if (aluout==4'd7) seven<=1'b1;
else if (aluout==4'd8) eight<=1'b1;
else if (aluout==4'd9) nine<=1'b1;
else result=zero;
end
endmodule
output reg zero;
output reg one;
output reg two;
output reg three;
output reg four;
output reg five;
output reg six;
output reg seven;
output reg eight;
output reg nine;
input [1:0] select;
always@(*)
begin
case (select)
endcase
end
endmodule
-R
sir when i synthesize it i get the message
WARNING:Xst:1306 - Output <result> is never assigned.
WARNING:Xst:737 - Found 4-bit latch for signal <$old_aluout_1>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
I have removed result as it is not used in code
after removing result i get this warning message
then when i tell it to generate bit file i get this message
pic attached
THIS is UCF
NET "select<0>" LOC = "H18" | IOSTANDARD = LVTTL | PULLUP ; //for select input
NET "select<1>" LOC = "N17" | IOSTANDARD = LVTTL | PULLUP ; //for select input
SIR bit file has been generated now
and let me check it
thanks sir for ur help
I tried to fix the code given and I think it will work as is.  It would be more normal have a clock input and instead of
always @ (*);
use
always @(posedge clk);
Respected Sir,
Thanks my Kit is working now and my problem is solved.
I am highly thankful to all other people who helped me
I was very much tired.
My sincere apologies if i said something harsh.
It is b/c of u people that i using this FPGA kit
Take care
and thanks to Sir Roym Again
This warning is pretty crucial.  If you look at this part of the code:
case (select)
endcase
"select" can have four values (2'b00, 2'b01, 2'b10 and 2'b11) and you've only told the system what to do for three of them.  Basically, it doesn't know what to do to "aluout" when "select" is 2'b11, so strange things might start happening.  I'd recommend fixing it.
Good point, This was cleaned up in a later thread.
http://forums.xilinx.com/t5/Spartan-Family-FPGAs/How-to-get-rid-of-warning-from-my-code/td-p/110530
-R
