How to pass variables to DCM
I am using DCM to create a new output from the input clock.
The entries for CLKFX_MULTIPLY and CLKFX_DIVIDE have to be integers.
I was trying to use variables instead of integers, but I got the error message:
The actual value associated with a generic must be a globally static expression.”
How can I pass integers to DCM through variables?
See attachments for my codes.
Re: How to pass variables to DCM
@pkiang How can I pass integers to DCM through variables?
The answer here is quite simple: you can't.
Attributes like CLKFX_MULTIPLY and CLKFX_DIVIDE are constants used to configure the DCM at compiletime.
Hope that clarifies,
Herbert
Scholar austin
p,
Its hardware -- you cannot.  To set all the configuration bits properly, the values must be known to create the bitstream.  A variable has no information, hence not possible (no bitstream).
You may reload the values after you are running using the DRP port of the DCM however, followed by a reset.  Note that other configuration bits of the DCM may also need to be changed through the DRP port as well besides just M and D.
Austin Lesea
Principal Engineer
Xilinx San Jose
Herbert
Scholar dpaul24
Use a constant of type integer, in the code which is not working.
If your target is to easily change the value, then you may use as follows-
constant DD   : integer := 20;
FPGA enthusiast!
All PMs will be ignored
Thanks for the quick and clear answer.
