How to store initial data in block RAM
HI
I wish to start  a  GPS receiver  from FPGA  more often . Hex string needs to be sent from FPGA to GPS receiver having  microcontroller via serial comm  is as
A0 A1 00 0F 01 01 07 D8 0B 0E 08 2E 03 09 C4 30 70 00 64 16 0D 0A
I wish to store this hex string  in block RAM after FPGA is turned on , so that FPGA  can retrieve this string whenever it is needed
Is there any way to acheive this using for loop ?
Faisal
Re: How to store data in block RAM using for loop
Faisal, why do you continue to want to use loops?
Loops are for software and should be rarely used in hardware.  You have 22 data words to be sent and simple counter and case state is all that you need to do this.
always @ (posedge clk)
begin
  if (reset)
     count <= 0;
  else if (count < 22)
     count <= count+1;
end
always @ (count)
begin
  case (count)
       0 : data <= 8'hA0;
       1 : data <= 8'hA1;
       21: data <= 8'h0A;
       22: data <= 8'h00; // end state
  default: data <= 8'h00; // default case just in case
  endcase
end
If you want to continue to use loops I would suggest that you spend time learning the simple PicoBlaze microcontoller and write this in PicoBlaze assembly code.
Teacher eteam00
Check the Language Templates for BRAM.  There is an 'init' facility example in the template.  It's not well-documented, but it's enough to allow you to figure it out in a few hours of 'dorking around'.
If you use the CoreGen BRAM wizard, there is an init facility by way of .coe file.  I think the wizard points to examples of the .coe file format...  if not, search the forums for the topic.  I'm sure it's been discussed before.
-- Bob Elkind
SIGNATURE:
Summary:
begin
  if (reset)
     count <= 0;
     count <= count+1;
end
always @ (count)
begin
  case (count)
       0 : data <= 8'hA0;
       1 : data <= 8'hA1;
       21: data <= 8'h0A;
  endcase
end
Thanks Mcgett
I was intending to avoid  this 22 lines . It seems it is not possible. So Based on Bob's suggestion
I wish  to use single port read only memory aiming that I can store this initialization string at the coregen wizard. There is one
load init file option , not sure how  to create this .cue file format .   Not sure  ???
Kind Regards
Faisal
Teacher eteam00
Faisal,
If you have trouble with the .COE file, you always have Ed's solution at the ready, if needed.
Ed's solution looks pretty simple.
I don't know how this translates in far away countries (this is a global audience), but there is a saying in this country:
There is more than one way to skin a cat.
I don't have any generate loops in my code.  But my code can be loopy in other ways.  :)
- Bob Elkind
SIGNATURE:
Summary:
So instead of writing 22 lines of code, you wrote 50+ lines of forums posts?   Even with a loop you would still need the same data.  An alternative is shown here:
begin
  if (reset) begin
     data  <= 176'hA0A1000F010107D80B0E082E0309C430700064160D0A;
     count <= 0;
     end
  else if (count < 22) begin
     data <= {8'h00, data[175:8]};
     count <= count + 1;
     end
end
assign data_out = data[7:0];
The amount of HDL lines is not important to the end result.  What the HDL describes however does matter.
The first code that I posted would genarate  5 registers and maybe 30-40 LUTs.  The second code is nearly all registers and would consume 181 registers and 10-15 LUTs.
The alternative with a BlockRAM would consume 5 registers, 10-15 LUTs and a BlockRAM.  Since BlockRAMs are limited using one in this limited fashion would be undesirable.
Moving to distributred LUT RAMs would consume about 5 registers, 10-15 LUTs and 8 LUT RAMs
Thanks mcgett
Sorry. I agree.
Oops ! Again I am adding lines to the forum :smileyindifferent:
Cheers
Faisal
Bob,
If want to write some 200 bytes of data into the blockram using the init template,read & write width would be 8 bits.
It means INIT_00 => x"0A"; right?
but how we'll manage to connect readaddr port &wrddr port .how/to which signal we'll map this ports ?
& also if we are writing initial data(hardcoding) into block ram what will be DI => DI,         -- Input write data port, width defined by WRITE_WIDTH parameter be connected to ?
with ref to this
--BRAM_SDP_MACRO : In order to incorporate this function into the design,
--     VHDL      : the following instance declaration needs to be placed
--   instance    : in the architecture body of the design code.  The
--  declaration  : (BRAM_SDP_MACRO_inst) and/or the port declarations
--     code      : after the "=>" assignment maybe changed to properly
--               : reference and connect this function to the design.
--               : All inputs and outputs must be connected.
--    Library    : In addition to adding the instance declaration, a use
--  declaration  : statement for the UNISIM.vcomponents library needs to be
--      for      : added before the entity declaration.  This library
--    Xilinx     : contains the component declarations for all Xilinx
--   primitives  : primitives and points to the models that will be used
--               : for simulation.
--  Copy the following four statements and paste them before the
--  Entity declaration, unless they already exist.
Library UNISIM;
use UNISIM.vcomponents.all;
Library UNIMACRO;
use UNIMACRO.vcomponents.all;
--  <-----Cut code below this line and paste into the architecture body---->
   -- BRAM_SDP_MACRO: Simple Dual Port RAM
   --                 Virtex-6
   -- Xilinx HDL Language Template, version 13.4
   -- Note -  This Unimacro model assumes the port directions to be "downto".
   --         Simulation of this model with "to" in the port directions could lead to erroneous results.
   --  READ_WIDTH | BRAM_SIZE | READ Depth  | RDADDR Width |            --
   -- WRITE_WIDTH |           | WRITE Depth | WRADDR Width |  WE Width  --
   --    37-72    |  "36Kb"   |      512    |     9-bit    |    8-bit   --
   --    19-36    |  "36Kb"   |     1024    |    10-bit    |    4-bit   --
   --    19-36    |  "18Kb"   |      512    |     9-bit    |    4-bit   --
   --    10-18    |  "36Kb"   |     2048    |    11-bit    |    2-bit   --
   --    10-18    |  "18Kb"   |     1024    |    10-bit    |    2-bit   --
   --     5-9     |  "36Kb"   |     4096    |    12-bit    |    1-bit   --
   --     5-9     |  "18Kb"   |     2048    |    11-bit    |    1-bit   --
   --     3-4     |  "36Kb"   |     8192    |    13-bit    |    1-bit   --
   --     3-4     |  "18Kb"   |     4096    |    12-bit    |    1-bit   --
   --       2     |  "36Kb"   |    16384    |    14-bit    |    1-bit   --
   --       2     |  "18Kb"   |     8192    |    13-bit    |    1-bit   --
   --       1     |  "36Kb"   |    32768    |    15-bit    |    1-bit   --
   --       1     |  "18Kb"   |    16384    |    14-bit    |    1-bit   --
   BRAM_SDP_MACRO_inst : BRAM_SDP_MACRO
   generic map (
      BRAM_SIZE => "18Kb", -- Target BRAM, "18Kb" or "36Kb"
      DEVICE => "VIRTEX6", -- Target device: "VIRTEX5", "VIRTEX6", "SPARTAN6"
      WRITE_WIDTH => 0,    -- Valid values are 1-72 (37-72 only valid when BRAM_SIZE="36Kb")
      READ_WIDTH => 0,     -- Valid values are 1-72 (37-72 only valid when BRAM_SIZE="36Kb")
      DO_REG => 0, -- Optional output register (0 or 1)
      INIT_FILE => "NONE",
      SIM_COLLISION_CHECK => "ALL", -- Collision check enable "ALL", "WARNING_ONLY",
                                    -- "GENERATE_X_ONLY" or "NONE"
      SRVAL => X"000000000000000000", --  Set/Reset value for port output
      INIT => X"000000000000000000", --  Initial values on output port
      -- The following INIT_xx declarations specify the initial contents of the RAM
      INIT_00 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_01 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_02 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_03 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_04 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_05 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_06 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_07 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_08 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_09 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_0A => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_0B => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_0C => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_0D => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_0E => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_0F => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_10 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_11 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_12 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_13 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_14 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_15 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_16 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_17 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_18 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_19 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_1A => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_1B => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_1C => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_1D => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_1E => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_1F => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_20 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_21 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_22 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_23 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_24 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_25 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_26 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_27 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_28 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_29 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_2A => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_2B => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_2C => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_2D => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_2E => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_2F => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_30 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_31 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_32 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_33 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_34 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_35 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_36 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_37 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_38 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_39 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_3A => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_3B => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_3C => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_3D => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_3E => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_3F => X"0000000000000000000000000000000000000000000000000000000000000000",
      -- The next set of INIT_xx are valid when configured as 36Kb
      INIT_40 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_41 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_42 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_43 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_44 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_45 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_46 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_47 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_48 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_49 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_4A => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_4B => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_4C => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_4D => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_4E => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_4F => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_50 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_51 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_52 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_53 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_54 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_55 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_56 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_57 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_58 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_59 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_5A => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_5B => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_5C => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_5D => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_5E => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_5F => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_60 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_61 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_62 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_63 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_64 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_65 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_66 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_67 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_68 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_69 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_6A => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_6B => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_6C => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_6D => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_6E => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_6F => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_70 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_71 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_72 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_73 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_74 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_75 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_76 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_77 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_78 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_79 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_7A => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_7B => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_7C => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_7D => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_7E => X"0000000000000000000000000000000000000000000000000000000000000000",
      INIT_7F => X"0000000000000000000000000000000000000000000000000000000000000000",
      -- The next set of INITP_xx are for the parity bits
      INITP_00 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INITP_01 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INITP_02 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INITP_03 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INITP_04 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INITP_05 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INITP_06 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INITP_07 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INITP_08 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INITP_09 => X"0000000000000000000000000000000000000000000000000000000000000000",
      INITP_0A => X"0000000000000000000000000000000000000000000000000000000000000000",
      INITP_0B => X"0000000000000000000000000000000000000000000000000000000000000000",
      INITP_0C => X"0000000000000000000000000000000000000000000000000000000000000000",
      INITP_0D => X"0000000000000000000000000000000000000000000000000000000000000000",
      INITP_0E => X"0000000000000000000000000000000000000000000000000000000000000000",
      INITP_0F => X"0000000000000000000000000000000000000000000000000000000000000000")
    port map (
      DO => DO,         -- Output read data port, width defined by READ_WIDTH parameter
      RDADDR => RDADDR, -- Input read address, width defined by read port depth
      RDCLK => RDCLK,   -- 1-bit input read clock
      RDEN => RDEN,     -- 1-bit input read port enable
      REGCE => REGCE,   -- 1-bit input read output register enable
      RST => RST,       -- 1-bit input reset
      WE => WE,         -- Input write enable, width defined by write port depth
      WRADDR => WRADDR, -- Input write address, width defined by write port depth
      WRCLK => WRCLK,   -- 1-bit input write clock
      WREN => WREN      -- 1-bit input write port enable
   -- End of BRAM_SDP_MACRO_inst instantiation
              Help on this would be much helpful!
