Visitor tiboy
I can't program FPGA using iMPACT11.1,here is the Console Information,please help me!
INFO:iMPACT - Current time:  30 10:23:01 2009
Maximum TCK operating frequency for this device chain: 10000000.
Validating chain...
Boundary-scan chain validated successfully.
'1': IDCODE is '00000010011000010000000010010011'
'1': IDCODE is '02610093' (in hex).
'1': : Manufacturer's ID = Xilinx xc3s50an, Version : 0
INFO:iMPACT - Current time:  30 10:24:31 2009
PROGRESS_START - Starting Operation.
Validating chain...
'1': SPI access core not detected. SPI access core will be downloaded to the device to enable operations.
INFO:iMPACT - Downloading core file C:/Xilinx/11.1/ISE/spartan3a/data/xc3s50an_spi.cor.
'1': Downloading core...
done.
'1': Reading status register contents...
CRC error                                         :         0
IDCODE not validated while writing FDRI           :         0
DCM Locked                                        :         0
status of GTS_CFG_B                               :         0
status of GWE                                     :         0
status of GHIGH                                   :         0
value of VSEL pin 0                               :         0
value of VSEL pin 1                               :         0
value of VSEL pin 2                               :         0
value of MODE pin M0                              :         0
value of MODE pin M1                              :         0
value of MODE pin M2                              :         0
value of CFG_RDY (INIT_B)                         :         0
DONEIN input from Done Pin                        :         0
SYNC word not found                               :         0
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0000 0000 0000 0000
INFO:iMPACT:2492 - '1': Completed downloading core to device.
INFO:iMPACT - '1': Checking done pin....done.
'1': Core downloading terminated. DONE did not go high.
PROGRESS_END - End Operation.
Elapsed time =      1 sec.
INFO:iMPACT - Current time:  30 10:24:36 2009
Validating chain...
Re: I can't program FPGA using iMPACT11.1,here is the Console Information,please help me!
Check you schematic design for configuration mode settings and bitstrim generator options. See UG332 starting with pages  52.
I think that this is the problem of setting "DONE" pin.
Se also http://survey.xilinx.com/ss/wsb.dll/Xilinx/Configuration_Debug_Guide.htm
Message Edited by kurgan on 01-06-2010 03:46 AM
Visitor tiboy
 I found an error in 'done' pin.
Done pin and init_pin prog_b pin  are connected to 3.3V together and I have separated them.It works!
Thank you!
