Visitor an5798an
INFO:iMPACT:583 - '1': The idcode read from the device does not match the idcode in the bsdl File
I met this problem.
INFO:iMPACT:583 - '1': The idcode read from the device does not match the idcode in the bsdl File.
INFO:iMPACT:1578 - '1':  Device IDCODE :        00000100000000001000000010010011
INFO:iMPACT:1579 - '1': Expected IDCODE:    00000100000000101000000010010011
My board info is
Xilinx Spartan-6 Lx45 FPGA in a 324-pin BGA package
I tried to pragram to my board with very simple Verilog of VHDL file. but I couldn't for this error.
It dosen't appeared any problem in Synthsize, Implement Design and Generate Programming File( generate .bit file)
I also success downloading program to device with another bitstream file .
But, The bit file I generate with my source code failed downloaded to my devive.
i'll attach my verilog source file , ucf file and bit file.
as you see, my verilog code is very simple . and doesen't occur compile error.
please, help me for this problem.
Community Manager
Community Manager
Re: INFO:iMPACT:583 - '1': The idcode read from the device does not match the idcode in the bsdl File
Which device are you targetting? Is it 6slx45t or 6slx45?
The expected device IDCODE corresponds to 6SLX45T whereas the device IDCODE is of 6SLX45.
Please regenerate the bitfile targetting the correct device to resolve this issue.
Krishna
Have you checked this AR
http://www.xilinx.com/support/answers/13529.html
Ashish
Community Manager
Community Manager
Krishna
Make sure that the device on the board and your implemented project should use  same FPGA part number
Visitor an5798an
Oh I solve it! It was my mistake.. Thank you very much.
Visitor fiberdigit
we recently received new batch of boards built with XC9536 CPLD with the following markings:
                VQ44AMM1034
                F2038386A
These boards have the same error when trying to erase the device.
However, we also have the same board built a while back with the same CPLD with the following markings:
               VQ44AMM0905
                D3631230A
This board has no issue at all when trying to erase the device.
I'm having a similar problem trying to program a xc6slx9: (what id code is 0xFFFFFFFF?)
rebooting the PC fixes the problems, but is a pain to do every time.
INFO:iMPACT:1578 - '1':  Device IDCODE :        00001111111111111111111111111111
INFO:iMPACT:1579 - '1': Expected IDCODE:    00000100000000000001000010010011
write cmdbuffer failed 20000015.
PROGRESS_END - End Operation.
Elapsed time =      9 sec.
