Initializing Block RAM with External Data File
It's my first post on this forum, so I'm a bit confused.
I would like to write an external file in order to externally initialize BRAM.
In XST USER GUIDE, it's said that
"The data file must be pure binary or hexadecimal content with no comments or
other information"
I wrote a pure binary data file and it's ok, but it's tiring to write 64 1 or 0 per line.
The problem is that I don't know how to write a hexadecimal file to initialize my BRAM.
I tried the notation (X"") like in VHDL but it didn't work. I also tried many others hexadecimal notation but I had the same results -> KO.
How can I do that ?
Re: Initializing Block RAM with External Data File
Thanks for your reply !
I finally find the solution.
I use hread() instead of read(). It's possible by including following line in the code :
use ieee.std_logic_textio.all;
So I post my code for those who could have the same "problem".
Thanks again.
My code describes an asynchronous read 512x24 rom which will be used as instruction memory in a small softcore processor that I'm designing.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use std.textio.all;
entity inst_memory is
port
addr: IN std_logic_VECTOR(8 downto 0);
inst: OUT std_logic_VECTOR(23 downto 0)
end inst_memory;
architecture behavioral of inst_memory is
type rom_type is array (511 downto 0) of std_logic_vector (23 downto 0);
impure function InitRomFromFile (RomFileName : in string) return rom_type is
FILE romfile : text is in RomFileName;
variable RomFileLine : line;
variable rom : rom_type;
begin
for i in rom_type'range loop
readline(romfile, RomFileLine);
hread(RomFileLine, rom(i));
end loop;
return rom;
end function;
signal rom : rom_type := InitRomFromFile("rom.data");
begin
inst <= rom(conv_integer(addr));
end behavioral;
Professor
Professor
It would help if you told us what language you're using.  For Verilog, the file format
is ASCII binary or hex (note that "ASCII binary" is not a "binary file in the usual sense).
Also the support for initializing RAM from a file depends on the ISE version.  At least
for Verilog I have found that using a new line for each entry is necessary, even though
the language reference manual indicates that any "whitespace" between values is
OK.
For example for verilog $readmemb and a 5-bit wide memory:
11011
10111
01001
11001
For $readmemh and a 16-bit wide memory:
2EA5
73F6
10A4
E4F0
9B41
In addition, XST likes the initialization file to have exactly the number of elements
required to initialize the memory.  Otherwise it will issue a warning that it has not
initialized the memory.
-- Gabor
-- Gabor
First , Thank you for your quick reply.
I'm using VHDL. I'm not used to Verilog.
I tried all hexadecimal notations. For example, for a 8-bit wide memory :
0xFF
0XFF
X"FF" like in VHDL
hFF
FFh
And all others possibilities. But it didn't work.
May be I use the wrong function.
This is a piece of my code (from XST user guide):
begin
end loop;
return rom;
end function;
Are functions readline() and read() suitable to read hexadecimal values instead of binary ones ?
Historian
Historian
0xFF
0XFF
X"FF" like in VHDL
hFF
FFh
begin
end loop;
return rom;
end function;
Check out what's in the textio package.
Thanks again.
library IEEE;
use std.textio.all;
port
end inst_memory;
begin
end loop;
return rom;
end function;
begin
end behavioral;
