Issue for Spartan 6 configuration Mode
We have the same spartan 6 application design for two projects seperated by 3 years.
We are experiencing the issue for spartan 6 configuration mode.
We pull down configuration mode Pin M1 with 10k resistor but this setup is not working for most recent design.
We have to use 2k resistor to repalce 10k resistor to make Spartan 6 be programmed by flash.
Please let me know what is the potential problem for above issue?
Do you think if it is possible the FPGA is not baked long enough before assembling?
Many thanks.
David.
Teacher eteam00
Re: Issue for Spartan 6 configuration Mode
Given that the maximum current for a Spartan-6 internal 'weak pullup' is 350uA - 500uA, a 10K pulldown R is too high a value to guarantee a LOW logic level.
-- Bob Elkind
SIGNATURE:
Summary:
Scholar austin
d,
I would check if you have contaminated water during the wash of the flux during assembly.
Austin Lesea
Principal Engineer
Xilinx San Jose
Teacher eteam00
-- Bob Elkind
SIGNATURE:
Summary:
Scholar austin
Whoops!
Good catch.  I was not thinking of the pullups.
I was only thinking of leakage of pins (<10uA).
Clearly you have found the cause:  the pullups may be stronger, or weaker as part of normal process variation.  A marginal resistor value may for some lots of material stop working.
Thank you!
Austin Lesea
Principal Engineer
Xilinx San Jose
It is so good to know.
Many thanks.
Have a nice day.
David.
