sha@hys
LVCMOS33 voltage levels
                  I have driven 3 pins of my FPGA to 1,0 and a clock respectively and get voltage levels of 3.3 ,0 and 5.2V(peak to peak) when I view waveform in analog mode in oscilloscope. I expect clock to be having 3.3V peak to peak. My clock is output from clock generator , given to ODDR2 to eliminate clock dedicated route false problem . In UCF file I have explicitly mentioned clock pin and other pins to be LVCMOS33 standard. Please explain why is this so? I want 3.3Vpp clock to drive DAC board. My code sgments are:
clockinstance_1 : clkgen
port map
(-- Clock in ports
CLK_IN1 =>CLK,
-- Clock out ports
CLK_OUT1 => open,
CLK_OUT2 => clk_25,
CLK_OUT3 => clk_12,
-- Status and control signals
LOCKED => LOCKED);
oddrinst:ODDR2 PORT map(
D0=>'1',
D1=>'0',
C0=>clk_12,
C1=>not(clk_12),
Q=>clk4DAC
With Regards
Shalini
Tags (3)
chapman
My guess is that your ‘clk_25’ signal looks more like a sinusoidal waveform than a square wave. If so, what you are observing is the overshoot and undershoot of every transition.
For an experiment, try dividing your clock with a counter and outputting a lower frequency square wave (e.g. <2MHz). Then I expect you will see that you do have a more square looking waveform which generally switches between 0v and 3.3v. Then look closely at each transition and see how much the signal overshoots or undershoots and for how long.
This is why outputs can be defined to have different slew rates and drive strengths and why correct termination of clock (and other critical) signals on circuit boards becomes such an important subject.
Ken Chapman
Principal Engineer, Xilinx UK
logison
Check your supply voltage on Vcco pins. I'm affraid you don't have 3.3V on that pins but 5V instead.
sha@hys
hello,
   No my VCCO is 3.3V only,not 5 V. Also when I drive 1 from VHDL program to pin in same bank , I get the same 3.3V only.
chapman
Ken Chapman
sha@hys
Thank you for reply. You are correct.
With Regards
shalini
