Maximum frequency of Spartan 6 -3 device
Where can I check what is the maximum frequency supported by Spartan-6 device with -3 speed grade?
Part no : XC6SLX4-3CSG225
Asan.
Re: Maximum frequency of Spartan 6 -3 device
Check DC characterization report for spartan -6 devices
These documents will be useful
http://www.xilinx.com/support/documentation/data_sheets/ds162.pdf
http://www.xilinx.com/support/documentation/data_sheets/ds160.pdf
http://www.xilinx.com/products/silicon-devices/fpga/spartan-6.html
Thanks and Regards
Balkrishan
Thanks and Regards
Balkrishan
Thanks for the response!
