Minimum JTAG clock (TCK)
    I am using spartan 6 FPGA in my design. I want to configure the  FPGA through processor. So i have connected the processor GPIOs to FPGA JTAG signals (TMS, TDI, TDO & TCK).
Mainly I want to know what will be the minimum  JTAG clock (TCK) that the Spartan 6 FPGA can accept?
Rahul.
0Hz Should be the minimum the datasheet doesn't actually specify the minimum. Max is specification is 33MHz
Hi Rahul
I am facing some difficulty in JTAG chain congiguration through freescale P1012 processor.
Can you send me the procedure for JTAG cofig.
I need to write XSVF through this.
regards
Vijay
