ferruscacore
Nexys2 Extra Inputs
Well, I'm trying to control the seven segment displays. To control each display I need four inputs (4 bits) to display the numbers 0, 1, 2.... 9. So I need 16 inputs, because there are four displays, but the nexys2 only has 12 inputs (8 slide switches and 4 buttons)... and that's not enough. I just wanted to know if there is a way to get more inputs or if the displays can share inputs or what can I do?
I have done all the .vhd files to do this (a mux, a frequency divider, etc) but I can't generate the .bit file.
Ps. sorry for the bad english
eteam00
Professor
Professor
Naaaahhhh.  You only need 2 pushbuttons.
  • One pushbutton increments the current digit (with wraparound to 0)
  • The second pushbutton "locks in" the current digit value and "opens" the next digit.
The current "open" digit should be flashing to indicate to the user which digit is "open".
Now....  what are you going to do with the 8 slide switches and 2 extra pushbuttons?
Another suggestion:
  • Use the 4 pushbuttons, one for each digit, to increment the value displayed in each digit.
  • Use one slide switch to change/hold the current values.  In "hold" position, pushbuttons are ignored.  In "change" position, all 4 digits flash.
-- Bob Elkind
SIGNATURE:
Summary:
balaji_coreel
hi,
You can use xilinx hardware debugging ip core "VIO" ,using that you can generate more number of inputs& outputs to your DUT.
regards
balaji
ruhix
send digits seperately in four clock cycle
 first clok cycle first digit
 second c.c. second digit
human can realize 16 frame second as a moving object therefore at least 16* 4 > per second change in digits
before that you  need to bbinary to decimal converter
jschimek
Vio can be used to create Virtual Inputs, but you will be forced to control these pins on a PC via JTAG. This is really a debug tool.
Toggling pins with a pair of pushbuttons is probably your best solution.
-Jon
