Visitor beequantel
No output on OSERDES2
I'm trying to use a OSERDES2 to serialize datas. The simulation of my complete design works fine but I've no output signal when my FPGA is programmed (I already checked that my measure was ok generating a square signal on the same pad).
After further readings I think I respect the clocking methodology of the SERDES. I use a SelectIO Interface Wizard which instantiate automatically a BUFPLL. This BUFPLL is feeded by 2 clocks generated with a PLL_BASE.
During design implementation I get a warning : clock net clk_950 with clock driver pll_i/clkout2_buf drives no clock pins.
This could be the source of my problem but this signal (from PLL_BASE) is correctly connected to the BUFPLL. The simulation of my complete design wouldn't be working if it were not the case.
serders_out : out_serdes8
PORT MAP (
	-- From the device out to the system
	DATA_OUT_FROM_DEVICE    => diode_trig_8_reg,
	DATA_OUT_TO_PINS        => synchro_out_vector,
	-- Clock and reset signals
	CLK_IN                  => clk_high,
	CLK_DIV_IN              => clk_low,
	LOCKED_IN               => pll_locked,
	--LOCKED_OUT              : out   std_logic;
	IO_RESET                => '0'
I can provide the design project in attachments if needed (it's a very simple design).
bee
Visitor beequantel
Re: No output on OSERDES2
I reduced the frequency at 570 MHz to give it a try and it's working fine.
So I increased the frequency at 855 MHz, still working. So I got back to 950 MHz => Working.... I did not change anything else that the clocking wizard... I've no more timing warnings...
Comparing the project I attached to this message and the one I got now I find that the clocking wizard removed the BUFG when I changed the frequencies. So that was my problem, there was no need for a BUFG instantiation from the PLL.
I don't think the limit is 750 mpbs, I've another design working at 1 GHz on Spartan-6 (Speed grade 3).
Here my Spartan 6 is speed grade 2 so the PLL is limited at 950 MHz.
thanks for the help
Take a look at the HDL Libraries Guide for Spartan-6, page 205.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx11/spartan6_hdl.pdf
Have you instantiated the primitive correct?
Is it possible that you're holding something in reset with the incorrect polarity?
Does your simulation simulate the top-module of your design, or a sub-entity?
What are the clock rates you are using?  Have you defined them in your ucf file? ( this is likely not the issue, but possible you've got a clock on a non-clock net and the tools aren't picking that up ).
What version of the ISE tools are you using?
Can you export the schematic of the post-synth design to a pdf/image and post it?
It sounds like something is getting optimized out ( that simulation doesn't do ).  If you post the full project I'll see if I can take a look.
Visitor beequantel
Thanks for your quick reply, answers in text.
I hope so, the primitives are automatically instantiated by the wizards.
I don't think so the simulation would not be working.
I simulate the top module and sub-entity, both working fine
I defined the input clock of my device in ucf file, the constraints on PLL_BASE generated clock are automatically inferred during synthesis. This input clock is at 95MHz. I generate 950MHz and 128MHz (950/8) by the PLL.
The last one : 14.7
I would be easier to take a look at the design.
I joined it to this message.
Hmm, so 950mhz likely is too high for the oseries2.  Look at page 93 of UG381:
https://www.xilinx.com/support/documentation/user_guides/ug381.pdf
You're trying to run the interface at 950mb/s ( 1 bit @ 950mhz ), where the upper limit of the Spartan-6 is 750mbps ( in 3:1 mode ).
This warning is displayed during implementation:
WARNING:Pack:2768 - At least one timing constraint is impossible to meet because component switching limit violations have been detected for
   a constrained component. A timing constraint summary below shows the failing constraints (preceded with an Asterisk (*)). Please use the
   Timing Analyzer (GUI) or TRCE (command line) with the Mapped NCD and PCF files to evaluate the component switching limit violations in
   more detail. Evaluate the datasheet for alternative configurations for the component that could allow the frequencies requested in the
   constraint. Otherwise, the timing constraint covering this component might need to be modified to satisfy the component switching limits
   specified in the datasheet.
Is it possible for you to run slower than 950mhz?
-TD
Visitor beequantel
thanks for the help
Hmm. Well I'm glad I could be the catalyst for your success!
