grem@1
Non BGA package replacement for XC6SLX452-FGG484C
Hi, Need help to identify if there is a replacement part for XC6SLX452- FGG484C that is non-BGA type package. thank you.
gnarahar
grem@1 The only non-BGA package in Spartan-6 family is the TQG144 Quad Flat package and is available only for lower end parts XC6SLX4 and XC6SLX9. Unfortunately there is no non-BGA package for the part you looking at.
- Giri
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
grem@1
@gnarahar Thanks for your immediate response. Do you have recommendations with close to the same pin counts and similar specs?
gnarahar
grem@1 I would recommend you touch base with our FAE's who will be able to understand your application and suggest you the part accordingly.
https://www.xilinx.com/about/contact/sales-offices.html
https://www.xilinx.com/about/contact/authorized-distributors.html
If this is a new design, I would recommend looking at the 7-series family as you can use Vivado and newer tools.
- Giri
grem@1
thank you. :)
