PID control implementation for DC motor control
Hi everyone. I want to design pid implementation for dual dc motor control. I am using the Spartan 3- starter kit board. I have ultrasonic range sensor and i can show the object's range on seven segment display as centimeter. And also, i can control dual dc motor by using pwm technique on fpga board. But, i can not put everything together.
I can get distance value as centimeter and i can control dc motor by using pwm technique but how can i put pid on it? or how should i write pid code? Could you please help me to get rid of this chronic issue?
Thaks.
Scholar jmcclusk
Re: PID control implementation for DC motor control
Here, let me fix that for you:
First the code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
-- PID pseudocode from Wikipedia  https://en.wikipedia.org/wiki/PID_controller
-- in an arbitrary design decision, the time interval dt = 1
--  previous_error = 0
--  integral = 0
--  loop:
--      error = setpoint - measured_value
--      integral = integral + error * dt
--      derivative = (error - previous_error) / dt
--      output = Kp * error + Ki * integral + Kd * derivative
--      previous_error = error
--      wait(dt)
--  goto loop
entity PID is
    generic( fraction_bits : integer := 8 );
    Port ( clk          : in std_logic;
           clk_en       : in std_logic;
           sync_reset   : in std_logic;
           Kp, Ki, Kd   : in signed;  -- control coefficients
           setpoint     : in signed;  -- input setpoint
           measured     : in signed;  -- feedback from external plant
           pid_output   : out signed  -- control output
end PID;
architecture Behavioral of PID is
    function imax(arg1 : integer; arg2 : integer) return integer is
    begin
        if arg1 > arg2 then return arg1; end if;
        return arg2;
    end function;
constant error_len      : integer := imax( setpoint'length, measured'length);
constant integral_len   : integer := error_len + 10;  -- give an extra 10 bits to integral, hope it doesn't overflow!!
constant derivative_len : integer := error_len + 1;
constant product_len    : integer := Ki'length + integral_len + 1;  -- This needs more computation
constant pos_limit      : signed(pid_output'length-1 downto 0)  := (pid_output'left =>'0', others => '1');
constant neg_limit      : signed(pid_output'length-1 downto 0)  := (pid_output'left =>'1', others => '0');
signal error            : signed(error_len-1 downto 0)          := (others => '0');
signal previous_error   : signed(error_len-1 downto 0)          := (others => '0');
signal integral         : signed(integral_len - 1 downto 0)     := (others => '0');
signal derivative       : signed(derivative_len - 1 downto 0)   := (others => '0');
signal product_sum      : signed(product_len - 1 downto 0)      := (others => '0');
begin
process(clk) is
begin
    if rising_edge(clk) then
        if sync_reset = '1' then
            error       <= (others => '0');
            previous_error <= (others => '0');
            integral    <= (others => '0');
            derivative  <= (others => '0');
            product_sum <= (others => '0');
            pid_output  <= (others => '0');
        elsif clk_en = '1' then
            error           <= resize(setpoint, error_len) - resize(measured, error_len);
            previous_error  <= error;
            integral        <= integral + resize(error, integral_len);
            derivative      <= resize(error, derivative_len) - resize(previous_error, derivative_len);
            product_sum     <= (resize(Kp * error, product_len) + resize(Ki * integral, product_len) + resize(Kd * derivative, product_len))/2**fraction_bits;
            -- now clip the output to prevent overflow/underflow
            if product_sum < resize(neg_limit, product_len) then
                pid_output <= neg_limit;
            elsif product_sum > resize(pos_limit, product_len) then
                pid_output <= pos_limit;
            else
                pid_output <= resize(product_sum, pid_output'length);
            end if;
        end if;
    end if;
end process;
end Behavioral;
Then a testbench:
library IEEE;
entity tb_pid is
end tb_pid;
architecture Behavioral of tb_pid is
component PID is
end component;
constant fraction_bits : integer := 8;
signal clk : std_logic := '0';
signal sync_reset : std_logic := '1';
signal Kp, Ki, Kd : signed(9 downto 0) := (others => '0');
signal setpoint   : signed(9 downto 0) := to_signed( integer( 2**fraction_bits * 1.0 ), Kd'length);
signal measured   : signed(9 downto 0) := (others => '0');
signal pid_output : signed(9 downto 0) := (others => '0');
begin
clk <= not clk after 10 ns;
sync_reset <= '0' after 100 ns;
Kp <= to_signed( integer( 2**fraction_bits * 0.5   ), Kp'length);   -- setup some coefficients
Ki <= to_signed( integer( 2**fraction_bits * 0.125 ), Ki'length);
Kd <= to_signed( integer( 2**fraction_bits * 0.25  ), Kd'length);
setpoint <=  to_signed( integer( 2**fraction_bits * (-1.0) ), Kd'length) after 1000 ns;  -- flip at 1000 ns
dut: PID
  generic map( fraction_bits => fraction_bits)
  port map(
    clk         => clk,
    clk_en      => '1',
    sync_reset  => sync_reset,
    Kp => Kp,   -- control coefficients
    Ki => Ki,
    Kd => Kd,
    setpoint     => setpoint,   -- input setpoint
    measured     => measured,  -- feedback from external plant
    pid_output   => pid_output  -- control output
measured <= pid_output;  -- model of external plant here
end Behavioral;
And here is the result:
Obviously, the damping is not very good with these coefficients..    A further challenge is to add automatic coefficient computation to make the controller critically damped, or as close as possible to critically damped.   This quickly gets deep into control theory, especially with non-linear or time varying plant models.
