PLL Clock generation fail.
Dear All,
I'm trying to make pll clock by using clocking wizard for making HDMI@1080p and HDMI@720p clock as the below,
Input clock is 150Mhz.
Target clock is 10x and 5x clock. then 1500Mhz and 750Mhz.
But clock Wizard does not support 1500Mhz.
So What am I supposed to do to get 1500Mhz?
ds162 states that Foutmax  for the PLL is 400MHz when driving a BUFGMUX and 1080MHz when driving a BUFPLL.  These numbers are for the -3 speed grade, others are a bit lower.  You would use a global clock buffer (BUFGMUX) when driving logic inside the FPGA.  The BUFPLL is related to high speed serial IO.
What in a Spartan 6 do you expect to run at 750MHz or 1500MHz?
@bruce_karaffa I think there are some module of PLL clock generator.
Did I something miss?
