PLL in Spartan 6 LX4
Is PLL available in Spartan-6 LX4 FPGA?
If so, please let me know the LogiCore IP name,
Asan.
Tags (3)
Hi @ajasan
Yes this device has two PLL's. Check this link http://www.em.avnetasia.com/Admin/Product/DownloadCenterFiles/26422a21-8533-4358-aae2-a97a11c0a320.pdf
You can use clocking wizard IP to generate PLL.
Deepika.
Deepika.
Hi @ajasan
Deepika.
Deepika.
Thanks for the response Deepika!
