eric_fpga
Problem in Implementing the 32bit initiator/target PCI Core
I've got evaluation license for PCI Core and want to design with Spartan3an.I can synthesize it, but when I want to implement my design(PCI Core is included)
I've got this error:
NgdBuild:604 - logical block 'PCI_CORE/PCI_LC' with type 'PCI_LC_I' could not be resolved. A pin name misspelling can cause this, a missing edif or ngc file, case mismatch between the block name and the edif or ngc file name, or the misspelling of a type name. Symbol 'PCI_LC_I' is not supported in target 'spartan3a'.
Can someone help me?
ezequielsasky
ezequielsasky
Take a look at table 1 http://www.xilinx.com/support/documentation/ip_documentation/pci32/v4_18/pci_32_ds206.pdf
Which version of the core you are using?
Is your device supported?
eric_fpga
I'm using version 3.167 of PCI Core.My device is xc3s200AN,its not supported,but according to Coregenerator software this IPCORE can be generated for my device.
Anyway,even when I choose XC3S400AN-FGG400-5C that is supported,I got the same error.
What is this for?
ezequielsasky
eric_fpga
Thank you very very much.It works
