hey all
I'm running an HDMI program I found it in a website
when i do Gernrate programm file
Ii give me this
ERROR:PhysDesignRules:368 - The signal <LED<0>_OBUF> is incomplete. The signal
is not driven by any source pin in the design.
ERROR:PhysDesignRules:368 - The signal <LED<1>_OBUF> is incomplete. The signal
ERROR:PhysDesignRules:368 - The signal <LED<2>_OBUF> is incomplete. The signal
ERROR:PhysDesignRules:368 - The signal <LED<3>_OBUF> is incomplete. The signal
ERROR:PhysDesignRules:368 - The signal <LED<4>_OBUF> is incomplete. The signal
ERROR:PhysDesignRules:368 - The signal <LED<5>_OBUF> is incomplete. The signal
ERROR:PhysDesignRules:368 - The signal <LED<6>_OBUF> is incomplete. The signal
ERROR:PhysDesignRules:368 - The signal <LED<7>_OBUF> is incomplete. The signal
ERROR:PhysDesignRules:10 - The network <LED<0>_OBUF> is completely unrouted.
ERROR:PhysDesignRules:10 - The network <LED<1>_OBUF> is completely unrouted.
ERROR:PhysDesignRules:10 - The network <LED<2>_OBUF> is completely unrouted.
ERROR:PhysDesignRules:10 - The network <LED<3>_OBUF> is completely unrouted.
ERROR:PhysDesignRules:10 - The network <LED<4>_OBUF> is completely unrouted.
ERROR:PhysDesignRules:10 - The network <LED<5>_OBUF> is completely unrouted.
ERROR:PhysDesignRules:10 - The network <LED<6>_OBUF> is completely unrouted.
ERROR:PhysDesignRules:10 - The network <LED<7>_OBUF> is completely unrouted.
ERROR:Bitgen:25 - DRC detected 16 errors and 0 warnings. Please see the
previously displayed individual error or warning messages for more details.
what would be the problem
Re: Problem
sh12@,
From where did you get the HDMI program? Did they specify to use it with specific ISE version? If Yes, then please use the same ISE version.
The ports <LED<x> are not driving anything in the design, hence these errors. You can try removing the LOC constraints on LED<x> from UCF file or assign a value to the output.
Also check the following AR#35228:
http://www.xilinx.com/support/answers/35228.html
--Syed
Re: Problem
sh12@,
--Syed
Re: Problem
hey @syedz thanks for your relpy
removed the LOC constraints on LED<x> from UCF file
and  work
