Programming with USB to Parallel cable
Hi all,
Unfortunately, I got a Spartan 3 starter board from the university, which has to be programmed with a parallel to JTAG cable. My laptop doesn't have a parallel port.
Therefore, I was wondering if it should be possible to program the FPGA with an USB to Parallel cable, connected to the parallel/JTAG cable. What do you think?
Instructor
Instructor
Re: Programming with USB to Parallel cable
Unless you are using custom, non-Xilinx software on the PC side, you are mistaken.  None of the Xilinx supported JTAG programming interfaces require a *parallel to JTAG* cable.  A USB-to-JTAG cable is the "normal" fixture supported by the Xilinx toolset.
Most modern laptops don't have a parallel port.
No, a USB <=> Parallel bridge cable or device followed by a Parallel <=> JTAG cable will not work with the Xilinx tools.  Suggest you obtain a USB <=> JTAG cable.  If the University doesn't have one, they should purchase some.  You can search the user forums, you will find plenty of references.  You can review the Xilinx product by searching the Xilinx website for "USB Platform Cable".
-- Bob Elkind
SIGNATURE:
Summary:
Thanks for your reaction. This is the cable I got with the FPGA: http://shop.trenz-electronic.de/catalog/images/products/Z-JTAG3_t1.jpg
New plan: right now, I only have a bitfile for the FPGA. Is it possible to transform this bitfile into an mcs file, so I can program the PROM? That way, I only have to program the FPGA once at the university and can work with it via the serial cable at home.
I am using a spartan-3 starter board with XC3S400.
Instructor
Instructor
There is an assortment of programming cable solutions which will work with this board, which do not require a parallel port.  Read the board user guide, UG130, Chapter 11.
Xilinx solution:  USB Platform cable
Digilent programming cables.  The preferred cable is probably this one.
-- Bob Elkind
SIGNATURE:
Summary:
Advisor
Advisor
Yes, you can use iMPACT for this. First hit on Google was a tutorial written by Digilent, MCS File Creation with Xilinx ISE Tutorial.
