weber1030
Questions about FIFO GENERATOR V6.2
Hello everyone ,I am a learner of FPGA,I met a problem these days.
Under ISE 12.3,I generated a FIFO with FIFO GENERATOR v6.2.Here are the properties
Page1: Independent Clocks (RD_CLK, WR_CLK), Block RAM
Page2: Standard FIFO
              Write Width: 16
              Write Depth: 256
              Read Width : 16
              Read Depth : 256
Page3: No item is selected
Page4: Reset Pin is not selected,default for other items
Page5: Default
Page6: Default
In the top .vhd file signal wr_clk is 500K Hz ,rd_clk is 5M Hz.
I want to realize a function by controlling wr_en and rd_en.when an external signal is enabled,write FIFO begins,when signal full is pulled up, write stops and at the same time read FIFO begins.After synthesizing,I made a simulation in MODELSIM.Here comes the problem.when writing process is done,wr_en is pulled down to '0' and reading begins according to 50M Hz,but after several data have been read out,signal full is still '1','1' lasts for 5 wr_clk clocks.
PS:I did another test under ISE 9.1(FIFO ) with the same codes,only to find that '1' of full only lasts for one wr_en clock.
Here I provide the .VHD file,some notes have been made.You can create a project and do a  simulation to preferably understand what I have said。Appreciates!!!
rcingham
For dual clock FIFOs like this, there have been problems with the behavioural simulation models, so I advise you to use the structural simulation model.
"If it don't work in simulation, it won't work on the board."
rcingham
hafblud
I am also having problem using the FIFO V6.2
I configured the FIFO (XILINX 12.2) as following (spartan3E)
  1. Independent Clock
  2. Block RAM
  3. FIFO width (R/W) = 8 bit
  4. FIFO depth (R/W)= 2048
The problem is when I write the FIFO, I cannot write above 410 bytes. The FIFO width is 2048 but it only writes 410 bytes. Why is so?
I am using 11.0592MHz Clock for writing the FIFO.
The second problem is that when I am wriring, I need to keep the wrEnable signal asserted for 5 wrClocks in order to write a single byte, this also i don't understand. Any help or guidance will be appreciated ?
regards
Ali
Tags (2)
